Does this sound like a failing torque converter?
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, May 26, 2014.
  1. gimpyshotrods
    gimpyshotrods
    No machine work is preformed prior to installing a Speedi-Sleeve. They are just driven on.
  2. yes the converter has to be opened up or replaced.
    The flanged bearing race between the pump and stator is broken.
    The sealing ring that is damaged is for the forward clutch.
    Probably broke when you pulled the pump.
    You can replace them with cast rings in this situation.
    The middle sealing ring for the direct drum can be left out to full feed the direct clutch ,but the reverse p***age has to be blocked in the case or VB..We'll ***ume it is , if you had high gear.
  3. bobss396
    bobss396
    When I run across something like that, I go to a local transmission shop to get their opinion. Carry in the whole deal and have them look at it. Chances they will have anything as in seals and most will do you an exchange on the TC for a good price.
    Bob
  4. hillbilly4008
    hillbilly4008
    from Rome NY
    The guy only had the steel replacements so I grabbed those. Question: I have the washers for the pump bolts. Is it acceptable to put a dab of rtv on them to insure it will not leak?
  5. bobss396
    bobss396
    I've never used any sealant on front pumps or any transmission internals myself. Just let the seals do their thing. The pump bolt holes are probably blind anyway.
    Bob
  6. saltflats
    saltflats
    from Missouri
    You can use some sealer on them but I have never had a leak problem with reusing them.
  7. hillbilly4008
    hillbilly4008
    from Rome NY
    This filter only has about 400 miles on it, yikes
  8. J. A. Miller
    J. A. Miller
    from Central NY
    Ouch! Looks like you're going to have to buy some more parts Joe.
  9. DoubleJ52
    DoubleJ52
    from Belton, MO
    Trans needs to be rebuilt
  10. hillbilly4008
    hillbilly4008
    from Rome NY
    I don't even want to mess with it now. I pulled one out of my reserve stash, gave it a quick lookin over and started putting it in today.
    What does the C2 cast into the bell housing signify?
