Technical Does this tach need a transmitter?
Discussion in 'The Hokey Ass Message Board' started by uglydog56, Mar 26, 2026 at 7:32 PM.
  1. uglydog56
    uglydog56
    It's a green line tach, so it should need a transmitter, right? It has 5 wires. But the back of mine doesn't look like all the ones I've seen on the Google. It has a cylinder selector (6 or 8) and it looks like electronicy things inside when I peeked in the gap. Do I still need a transmitter? Thanks for your help. IMG_20260326_191619602.jpg IMG_20260326_191536215.jpg IMG_20260326_192317349.jpg
  2. tubman
    tubman
    With that many wires going into it, it shouldn't need a transmitter. But, that has weird color-coded wires. Normal tachs have :
    Red - Power
    Black - Ground
    Green - Tach Signal from distributor
    White - Light
    That has Red, Green, Blue, and Yellow. The first thing I'd do is take it out of the case and trace the wires and see if you can make sense out of where they connect. If it doesn't come apart, I'd ground the blue wire and momentarily apply 12 volts to the yellow wire and see if it lights up.
  3. See if you can get a circuit diagram for it, and post it up here. I'm sure someone here can decipher it, even me.
