Dohc
Discussion in 'The Hokey Ass Message Board' started by Stone, Feb 7, 2005.
  1. Stone
    Stone
    This was a interesting thread.To me at least. Maybe some new members have more to add or would enjoy reading it.
  2. Stone
    Stone
    Does anyone know anything about this?
    Deuces likes this.
  3. Parts48
    Parts48
    from Tucson, Az
  4. Weasel
    Weasel
    Moser DOHC conversion for SBC ca 1971 - Tom McMullen had one in one of his cars - may have been in his roadster at some time.
  5. rq375
    rq375
    from Washington
    Gurney-Weslake heads for small block Ford were pushrod with shaft rockers (inline vlaves, not canted) but had radically raised intake ports, and the injectors or webers bolted directly to the head without an intermediate intake manifold. There was a seperate valley pan. The exhaust ports were also raised to the point that they did not work with the shock towers of the production Fords of the era. Gurney Westake also produced a DOHC V-12 engine for their F1 efforts.
  6. chappys4life
    chappys4life
    from Austin, TX
    Didn't pontiac do something like dohc with their 6 cylinders that went into tempest/le mans? I think 68 right?
  7. Weasel
    Weasel
    W-E-S-L-A-K-E there is no T in the freakin' name.
  8. Stone
    Stone
    I love this stuff.
  9. noboD
    noboD
    They were single OHC. There was one local that was fairly fast for what it was.
  10. Allison and Rolls made some nice OHC engines back in the mid-1940s, but the displacement, at 1710 cu in, is a bit too high for a car. Oh, and they are in a V-12 configuration, so it might not fit between your Duece rails, radiator and firewall. ;-)
  11. junior 1957
    junior 1957
    look closely at that brabham repco f1 v8. that's an olds/buick 215 cu inch based block
    KiWinUS likes this.
  12. Weasel
    Weasel
    1953 Pegaso Z102B - this is actually a V8 3.2 liter four cam engine, gear driven cams with very rare dual quad Webers. The car also feature a torque tube, rear mounted ZF 5 speed with inboard brakes. The Z102 first appeared in 1952. Impressive for any car of that era, let alone a road going grand tourer.
  13. angrychairmen
    angrychairmen
    few maserati ghib that have been through the shop
  14. Stone
    Stone
    Some of those would look killer in a model A or other hot rod.
  15. GlenC
    GlenC
    Don't know if it's been metnioned as I haven't read all the posts, but here's the English Triumph Stag SOHC V8 from the 1970's. Plagued with overheating and warping problems at birth, many of these were swapped out for anything else that would fit in the engine bay, but modern technology has solved all the issues and the engines can now be built to be reliable.
    Absolute screamers, 6700 read line, 3 litre, all aluminium I think, certainly alloy heads. Backed up by a 4 speed manual with overdrive. Almost 3000 of them were imported into the US, so they may well be around in old s**** or wrecking yards.
    Cheers, Glen.
  16. Areopagitica
    Areopagitica
    I just posted a copy of my global matrix of V8 engines, OHV and OHC, and some early DOHC V8s exist. The 303 Miller. The Novi Indy of 1941-66. Mercedes GP W165 of 1939. Both supercharged. Alfa's Trevisan prototypes of 1937. Czech air-cooled Tatra 603. Riley Autovia was high cams in block. Goossen Indy Stude of 1952 was the finest work, 4 valver injected, and is viewable in Bill Smiths Nebraska museum. Something similar on a DeSoto from the same designer. The Lancia GP of 1954 and 270 inch Maserati 450S of 1957. The Ford 1100 cube Sherman tank engine. The Coventry Climax 2.5 litre GP of 1954.
  17. Areopagitica
    Areopagitica
    If you wanna inquire on any of the above, feel free to query my Facebook blog, called Looking Back Racing. It pulls up in Googlesearch.
  18. Tritone
    Tritone
    For someone with really BIG ideas, here's a GAA available in NH for $7000
  19. PARPRO
    PARPRO
  20. Deuces
    Deuces
    Sent what from your iPad?????…...:confused:
    VANDENPLAS likes this.
  21. My great friend Rabbit originally from Melbourne Australia now Dahlonega Ga. dynoed every one of these.
    Deuces likes this.
  22. Pete Eastwood
    Pete Eastwood
    from california
    Wills St Clair was an American made car , 1921 - 1927 .
    They were equipped with a single over head cam V8 .
    X38, VANDENPLAS and Deuces like this.
  23. mgtstumpy
    mgtstumpy
    Not a regular production street engine
    https://bringatrailer.com/2018/04/26/technically-interesting-ford-indy-dohc-v8/
    Original design parameters indicated sustained 8000 RPM running. Final specs included a 3.760″ bore and 2.87″ stroke for total displacement of 255ci, and running a 12.5:1 compression ratio the so-called Ford Double Overhead Cam Compe***ion Engine delivered 495 HP at 8300 and 330 lb. ft. at 7000–for qualifying the redline was extended as far as 9200 revs.
    Deuces and VANDENPLAS like this.
  24. Rusty O'Toole
    Rusty O'Toole
    Jay Leno's first drive, in his 1922 Wills St Claire OHC V8
    Deuces, X38 and mgtstumpy like this.
