Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I've got a pair of 50 year old 28 spline 5 lug axles from a 1963 Falcon eight inch V8 rear... If you've got an eight inch rear in the car now..
  2. Bigcheese327
    Bigcheese327
    Thanks for the offer, but the current rear is something like a 7.5 or 7.25. Very weak and not very easy to find parts for. OK for a six-powered cruiser, but not desirable for a V8 swap like the 8".
  3. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    That's kinda' what I figured but I thought of put it out there for ya', just in case...
  4. Bigcheese327
    Bigcheese327
    This is what made me seek out the wagon rear.
    Dispatched from my 1949 Underwood Master.
  5. falconeer
    falconeer
    Burnt Out,
    To bad that you are not closer to me. The mav.-comet 8' is still fairly common in my area. I lucked up about 4 months ago and found a 8" v-8 rear end out of a 63 4 dr. Gona use it in my 62 Ranchero build. Was gona use a mav.-comet 8" and have it cut about 3/4" but now I can use the 63 rear and not do any thing but bolt it in. Even a blind hog finds an acorn every now and then.
    Butch Evans(Falconeer)
    Thomasville NC
  6. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    So it was rainin' this morin' n' I got all bored. I figured there was no time like the present to ditch my ******* bars n' install my spiffy new Cal-Track bars.
    First I removed the spring plates n' the spindly 3/8" U bolts along with my heavily modified Lakewood "universal" ******* bars.
    Check out the spacers I made to keep the *******s centered on my 2" springs...:eek:
    Then my buddy yanked out the springs...they came out pretty easy- the same dude had helped my replace the 50 year old springs n' hardware in May of 2012.
  7. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    After lubing the front spring eye up with anti-seize (never use as a personal lubricant) I pressed in the supplied aluminum bushing on my cheesy Chinese press.
    I used a bearing race installer that looked 'bout right n' a Jim's Harley 5 speed transmission main drive seal installer mostly because I couldn't find a piece of s**** pipe that was the right size.
    Front spring eye bushing installed.
    Pivot ***embly n' steel insert installed...
  8. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    After a lot of grunting n' bad language, the springs got re-installed with the new pivot ***emblies.
    Next up were the new spring plates and some 65-67 Mustang 7/16 U bolts.
    I would'a like to use 1/2 diameter U bolts but couldn't find any 2 3/8" U bolts for my eight inch rear in half inch...
    And no dude, I don't live on the left coast where there's a spring shop, a radiator shop n' an upholstery joint on every corner.
    All the local spring shops just laughed when I asked for a 1/2 x 2 3/8 x 6" round U bolt....
    So anyhow, here it is:
    Now I gotta' wait till it stops rainin' to try em out.....
  9. 1971BB427
    1971BB427
    from Oregon
    Must be a Ranger axle with the small tube diameter at the end? I had the opposite problem with my 8.8 Explorer; the tube was too large at 3.25" I used 3" U bolts on the tube, and reworked them to fit the 3.25" tube.
  10. 63comet
    63comet
    In the first pic it looks like the Cal Trac shock plates are set up for staggered shocks? What did you do about that?
  11. 63comet
    63comet
    Never mind! I zoomed in closer and see that they have tabs on both ends for the shocks to mount. Crafty.
  12. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Big block- it's a dead stock 63 Falcon V8 8in housing-
    I'm told the 63 Falcon is the narrowest hosing Ford ever made- the tubes are stepped down to 2 3/8" and take the small axle bearings. I know Mustang 8in rear housings are like this too because the parts interchange with the Falcon..
  13. 1971BB427
    1971BB427
    from Oregon
    Thanks! Didn't see the center to know what it was. I did notice when looking for the 8.8" for my Falcon that Rangers with the 8.8" used a stepped tube also.
  14. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I kinda thought ya' might a' seen where I swapped out my 3:55 trac-lock center for a 3:80 TL center a coupl'a pages back...
  15. 1971BB427
    1971BB427
    from Oregon
    Yeah, now that you mention it I did. But my memory is about 2 seconds long! :) I can walk from the car to the tool box and not remember what I was going to get!
  16. hotroddon
    hotroddon
    EXCITED! A few years back I put a Unisteer Rack and Pinion in my 63 Convert. It fit well, steered nice, but has the turning radius of a dump truck. It was so bad that at one Autocross event if I didn't Drift one corner (not the fast way around) I had to make a 3 point turn (Even slower way around). I kept looking at alternatives but wan't happy with any. Some guys modify either Chevy Cavalier or other OEM racks, but I never saw a conversion that i was all that happy with. TCP made a really nice looking unit, but you had to cut the driver's side frame rail and box it in to clear the rack - I wan't too thrilled about that. Flaming River kept saying they had one coming out, even advertised it, but every time I inquired it wasn't available yet. In the end, I had Total control make me a rack using Woodward Precision Steering Components (they build a lot of circle track steering) in a new design that doesn't require frame mods. Well it came in last night so Saturday I will be under the car installing it and my custom Aluminum Road Race oil pan (originally a Stef's Fabrication pan for a Mustang).
    I'm excited - will take pictures and post next week
  17. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I'd really like to see how that goes for ya', too.
  18. Bigcheese327
    Bigcheese327
    Should be interesting. I've never done much thinking about R&P because of all the issues with the Unisteer rack (and because I've never been unhappy with a steering box), but it will be interesting to see one done right.
  19. hotroddon
    hotroddon
    Once I started autocrossing and open track day running my car, I didn't like the feel of the stock steering linkage. The early Unisteer units had a bad bump steer issue, but that was sorted out, so now the radius was the problem. Probably not a big deal for a street car.
  20. Bigcheese327
    Bigcheese327
    I've always wanted to try Autocross, but for now mine's strictly a street car. I'll still be looking with interest!
  21. 63comet
    63comet
    I used to autocross my GT6 some. Stayed in stock as that kept me in one of the lower cl***es, mostly older 4 bangers. Poor thing got bumped to A soon as you did any mods and I didn't want to spend the money to run with Porsches and such.
    I couldn't imagine auto crossing the Comet. At the least I'd need much faster steering, or maybe I've just let myself get old and lazy.
  22. falconizer_62
    falconizer_62
    Let us know how the rack works out. I put a unisteer rack and hate the turning radius. I have to use my right foot for U-turns on some 6 lane roads. It doesn't give me much steering angle to correct drifts either. How much was the whole set up? did you keep the unisteer u-joints and steering rod?
  23. Kickstarter
    Kickstarter
    from NC
    Does anyone know of a source for stock 8" axles? I've got a Maverik rear end for my 64 wagon and it has one bad axle.
  24. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
  25. 63comet
    63comet
    If'n you go with new axles its a good time to rethink rear brakes too!
    I wish I'd been thinking more ahead, I would have got the axles machined to fit the brakes and wheels I am using so I could have skipped the spacer.
  26. 63comet
    63comet
    And... Over on TFFN there has recently been a thread started on electric power steering conversions that has me very interested.... I like the idea of bein able to get power steering without adding more under hood clutter. I can handle under dash clutter, I don't have I see it!
  27. need louvers ?
    need louvers ?
    No offense intended, I just can't imagine needing power steering on one of these cars. My wagon is too light for my tastes just flat dead stock.
  28. 63comet
    63comet
    I'd like to do something to reduce the turns lock to lock. With my new tires the standard steering box makes things kind of heavy when parallel parking. In Savannah you do a lot of parallel parking. With the stock tires I could pretty much park with my pinky.
    I have been contemplating just swapping to the faster power steering box alone and seeing if I an handle the increased effort without boosting things.
  29. need louvers ?
    need louvers ?
    What are you running for a steering wheel?
  30. 63comet
    63comet
    Stock... Whatever size that is? My 6'3" self can barely fit in there.
    Another reason I'd like power. I would like a hair more room in there.
