Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. nuts4fords
    nuts4fords
    Here are the custom subframes formed and tucked nicely to the undercarriage of my 64 Falcon hardtop. Super solid and ready for some serious torque :) This included a 4 pt. roll cage, minitub and rear leaf relocation. BF/X theme build with a wild 331 stroker, 4 spd top loader and a narrowed nodular 9" inch.
      53.6 KB
      44.9 KB
      42.3 KB
      32.5 KB
      58 KB
      39.8 KB
      55.9 KB
  2. falconizer_62
    falconizer_62
    WOW! Great work.
  3. nuts4fords
    nuts4fords
    Here are the custom subframes formed to the undercarriage of my 64 Falcon hardtop. This included a 4 pt. roll cage, minitub and rear leaf relocation.
  4. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Nice work! I dig the tastefully done wheel tubs and the relocated spring eye pockets (and the Cal Track pivot).....
  5. tedley
    tedley
    from canada
    Cool little cars. A friend of mine just put his on the road with a 302 5 spd Granada spindles and disc brakes. Blast to drive and a real sleeper.
  6. DAGONITWIT
    DAGONITWIT
    from NO VA
    Just curious if anyone has weighed their V8 Falcon? Most information that I've found says 2300 lbs. I'm ***uming that's dry with a 6 cyl. but even then, that sounds lite to me.
  7. DAGONITWIT
    DAGONITWIT
    from NO VA
    Hey Nuts, what size tire can you fit in there? What is the rear length?
    Nice looking work!
  8. frankenfords
    frankenfords
    from SoCal
    The factory weights are typically 'shipping weights', which means dry; i.e. not oil, gear lube, coolant, fuel, etc.
    I weighed a 61 Falcon 2dr wagon with a 289, iron case toploader 4spd with iron bellhousing, Versailles 9-inch rear with disc brakes, front disc brakes, subframe connectors, no headliner or carpet at 3,160 with a 1/2 tank of gas. Bear in mind, the disc brakes all around add a few pounds, the 9 inch adds a few pounds, the cast iron trans adds a few pounds, and being a wagon with the extra steel and gl*** adds several pounds.
  9. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Last year I had a buddy who's a Motor Carrier Safety cop (trucker ****er) come by and weigh my 63 2 door sedan:
    Here's what we came up with:
    3/4 tank (12 gallons) and I (175lb) was sittin' in the car.
    RF 700
    LF 850
    RR 625
    LR 675
    At that time it had a 1980 Lincoln 5.0 V8.
  10. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Thanks to fellow VA HAMB'r DAGONITWIT, I got a set of 14X6 Magnum 500 wheels to check out to see if they'd work on the old Ford:
    They seem to work with the Granada Disc brake set up, but the wheel center cap's attachment hardware wouldn't clear the bearing caps on the rotors:
    Although I've become really attached to my dog dish caps, I might just give these a try:
    The wheels have 185/70R14's. I have 195/70R14's on the car and they're 7 3/8" wide at the tire bulge (on 5" wide wheels), about the same width as the 185's that are on the 6" wide wheels now.
    Next week I'll try a 195 tire mounted on one of the Magnum wheels and see if it will clear the left rear inner fender lip, where I only have 1 3/8" clearance with the current wheel/tire combo.
  11. Burnt Out , Those look smart on there . Have you tried a 195/70 on the rear yet ?
    It's been a backward *** week here ...
    it feels a little bit like I've had to take two steps backward to get one forwards , but I got a decent result in the end .
    On the few short runs we've done in the car over the last couple weeks It had felt very Harsh in the driveline . So I set the car on jack stands so that the suspension was "loaded" at ride height and checked U/J angles with my digital angle finder ... 3.5 degrees difference. I thought "that'll be it " , removed the lowering blocks and milled a Taper on them to correct the pinion angle .
    Refitted blocks and drove again , noticeable improvement but still felt like It had a "Harmonic" vibration through the car , this road test was also the first decent blast on open highway and I realized the car felt very low geared .
    Went home jacked up one rear wheel and checked rear end ratio ... 3.5:1 . ******!
    Oh well , there is a 2.9:1 head in the Mustang 8" that is in the corner of the shop, destined for another project that will be running taller tyres ( Tires!).
    I gave some thought to what else could be causing the Harmonic issue and then decided to do a little home work on engine balance , as in Front Balancer and external weights on Flex plate/flywheel .
    Early Windsors use 28oz Weight on the flex plate/flywheel and late wiindsors use 50oz right ... ******!
    At this point I figured if it was a balance issue I should be able to feel it when the car is stationary. So I ran the engine at approx 3000-3500 rpm and rested
    my hand on a valve cover , yup it feels really harsh and is almost "pulsing" . ******!
    So yesterday , Out came the Motor and trans , I swapped out the Flex plate for the correct one , and also fitted a sandwich plate between the motor and trans. I had purchased the motor and box as an ***embled unit and it did not have a sandwich plate fitted . I had just finished up refitting motor and trans when
    Wifey came home from work ( late afternoon ) . She saw that I had the motor and back in and all ****oned up and says "So have you swapped out the Diff head too ?" I replied ," no that's tomorrow morning's job" .
    Well she looks at me with a cheeky grin and says she will help if we can do it NOW . So I'm back under the car and she is p***ing me tools and diff heads
    while removing wheels and brake drums . Didn't take long with the two of us on it .
    So today we have a '60 Tudor with a happy SMOOTH running 289 that goes down the Highway with no nasty vibrations and is not screaming it's lungs out at 70 mph . Bring on the weekend , I need a rest !
  12. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Damn, four six, you're makin' us all look lazy....I'd rather have my *** kicked than pull my engine/trans combo, again.
    And it would take an act of the United States Congress to get my Missus to help me change the third member. She hates the smell of friction modifier n' hypoid oil.
    I tried the 195's on the rear- gotta' get the fender lips rolled.
    My insane painter/body man will do it as soon as he runs out of dope and needs more cash....He was ******* and moaning about the double lip and thick old steel and twenty year old lacquer paint the whole time we were talkin' 'bout it.
    I'm in the midst of repainting the wheels now. I'm gonna' lose the chome trim rings and paint the wheel rims/depressions satin black and the spokes argent.
    BTW, the spiffy wheel mask kit I bought isn't even close...I used fine line masking tape.
    Or I might change my mind and paint them completely black...
  13. bengeltiger
    bengeltiger
    I'm digging that bumper! Nice and tight, great detail!
    Sent from my ADR6410LVW using H.A.M.B. mobile app
  14. 1971BB427
    1971BB427
    from Oregon
    Might look into subframe connectors for the same year Mustang. Often Mustang and Falcon used similar setups, with just length being different. On my '63 I found a NOS pair for an early Mustang and they bolted up perfectly in the rear, but didn't reach to the front frame rails, so I cut them and fabbed a new front mount to make up the difference. Then I fabbed tubing to tie them into the stock body supports and rockers. They were cheap, and easy to modify, and really tightened everything up well!
  15. 63comet
    63comet
    I would like to see someone m*** produce just the ends for the subframe connectors, let the consumer source their own tubing.
    It would make shipping easier and simplify dealing with Falcon/Comet/Mustang/Etc... differences.
  16. 1971BB427
    1971BB427
    from Oregon
    The ends are usually such a simple affair, that I can't imagine anyone with a welder couldn't build their own easily. If I hadn't stumbled across a NOS pair I'd have built mine from scratch cheaper than what most places sell them for.
  17. bengeltiger
    bengeltiger
    That wagon is sweet! Proportions looked great.
  18. bengeltiger
    bengeltiger
    Don't know if you got an answer, but, yes, the stud just rests on top of the tunnel and screws up/down to adjust. (At least it does on my 63 ht)
  19. bengeltiger
    bengeltiger
    Hood lookin' good!
  20. Leon Sandcastle
    Leon Sandcastle
    Could someone please help a guy out and show me the shelby drop setup?
  21. 63comet
    63comet
    The template or a pic of the moved arm? If you google Shelby drop template you should be able to find a printable one that can be transferred to steel.
    I didn't think to take any pictures while I had my front end apart.
  22. hotroddon
    hotroddon
  23. Leon Sandcastle
    Leon Sandcastle
    Thanks guys.
  24. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
    Hey guys,need some info on my f/end,i've got a 63 futura with a 289 and p/steer,q/s is will the mustang parts,tie rods,ball joints p/s ram etc fit my car,thanks Gaz!
  25. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    For a US model, the short answer is no. Mustang center link (or drag link)is wider. Depending on the Mustang's model year, the ram and ram mounting are different. I'm pretty sure power steering pitman arm on the steering box won't interchange either. Inner tie rod ends are also different.
    Some pretty good info here:
    http://www.stangerssite.com/centerlinks.html
    http://www.stangerssite.com/controlvalvepics.html
    http://www.stangerssite.com/PC_IDchart.html
    Click on the topics at the top of the page for additional info.
    I went the other way and ditched the sketchy Ford power ***ist system for the later V-8 manual set up....
  26. falconizer_62
    falconizer_62
    The radiator is finished. Now time for the cowl and to smooth out the dash
  27. hotroddon
    hotroddon
    Upper Ball joints are the same
    Lower Ball joints and control are are the same
    Outer tie rod ends are the same
    6 cylinder Idler is the same
    V8 idler is different
    Pitman arms are different - Falcon is 1 1/8" shaft, Mustang is 1"
    center drag link is different
    Inner tie rods are different
  28. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
    Thanks guy's,now I can get on with it,after I do the suspension and steering,i''ll move on to the interior,can you recommend a company who does a quality repop,i need seat covers,door panels and dash pad for a 63 futura conv with split bench .
  29. seb fontana
    seb fontana
    from ct
    Do all the Fomoco cars that have that basic front end [I beleive it ended 77' os so with the Mav/Comet] can use the Shelby drop or does it change some by make/model/year? I ask because I think I read some wheres that some of the drop was factory done in later years..
  30. bengeltiger
    bengeltiger
    Falconizer, you do excellent work! Each time I log on I check to see if you've had an update. Thanks for sharing!
