Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. Russco
    Russco
    from Central IL
    Yeah, we just recently added the new blown motor (347). We had a single carbed 302 in it originally, but it just wasn't fast enough.... he will have to change that over the winter.
  2. bengeltiger
    bengeltiger
    Russco, that thing is nasty! Thanks for sharing!
    Sent from my ADR6410LVW using H.A.M.B. mobile app
  3. Russco
    Russco
    from Central IL
    Thanks, Its my brothers car. I just helped on the build. Its pretty fun we had a 5.42 gear in it for awhile. Talk about a stop light to stop light killer.
  4. TooManyFords
    TooManyFords
    from Peotone IL
    Would love to see it in person.
  5. DAGONITWIT
    DAGONITWIT
    from NO VA
    Is the Mustang bumper not even close?
  6. Russco
    Russco
    from Central IL
    Gary, I'm sure we'll cross paths with you this year we put a 3.89 gear in it now so he can actually drive it down the interstate. I don't know about driving it to Kentucky though....
  7. falconizer_62
    falconizer_62
    nope, it has a little jog in it, and you can't bend it or cut it out. Camaro is better that way...
  8. falconizer_62
    falconizer_62
    Rattle can rebuild. It's much better to look at now :)
    Next up is painting the cowl and the dash. Before I do this, I need the ac vents cut into the dash. 1 rectangle for the middle, and 2 round ones on either side of the dash.
    Does anyone know of a good source for these? They can even come off a late model if they look cool and aren't plastic looking. I would appreciate any input. Thanks :)
  9. Have a look at 63 impala AC vents . Will be very close to what you need and available as a new part.
    Sent from my GT-S7275R using H.A.M.B. mobile app
  10. Locoxp
    Locoxp
    What about 64 Cadillac for the round ones and 69-72 blazer centre unit if it fits. Kinda need something with some shape like the dash
  11. tpw35
    tpw35
    I need an opinion on leaf springs, On my 65 falcon I need to replace the leaf springs with v8 springs, I currently have the 3 leaf 6 cylinder springs on it, I can get 4 or 5 leaf springs from Summit. Which ones should I go with, the car is street driven and I will ocasionally race it.
  12. ffej
    ffej
    ^^^^ Drag race or road course/Auto X race?
  13. tpw35
    tpw35
    drag race occasionally, street driven.
  14. 1971BB427
    1971BB427
    from Oregon
    Might try Laurel Mountain Mustangs. I just got springs for my '63 there, and much cheaper than anywhere else.
  15. gimpyshotrods
    gimpyshotrods
    65-66 Mustang springs fit. What there are a ton of choices. I run 6-leaf springs in my customer's cars. Stiff, but not too stiff. Can be had from a variety of suppliers. I like them from ESPO, made with 2" less arch. Not the same springs, exactly, but I run the ESPO 6-leaf springs, with less arch, in my daily-driver '60 Falcon. Downright sporty, with 560-lb. coils, 1" front bar, and Shelby control arm relocation.
  16. hotroddon
    hotroddon
  17. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    For the time being, I'm running five leaf stock length rear springs on mine that I got from a vendor called "Spring King" on egay.
    This past summer, I decided to ditch the ******* bars because they just weren't doing it for the rear suspension.
    I went with a set of Cal-Tracs bars and the Calvert Racing adjustable rear shocks. The shocks, bars and springs were just to big'a bite for me, money-wise, all at once.
    I plan on getting a set of the split mono-leafs after the first of the year.
    The dudes that I know that have the mono-leafs, swear by them.
    Although opinions may vary.....
  18. Bigcheese327
    Bigcheese327
    While we’re talking about springs and rear axles, I’ve a question for the guys running big-tube rear axles in their cars: I’m sticking a ‘56 Ford wagon rear (Dana 44) in my wife’s ‘61 Futura. It came without the shock plate. What can I do to replace them? I’m still running the narrow early Falcon springs.
    Thanks!
  19. gimpyshotrods
    gimpyshotrods
    I am running an 8.8, from a Ranger. I just got late 60's Mustang plates and u-bolts. The u-bolts are outboard of the springs a little, but it hasn't been a problem, in 10k miles. The Mustang vendors have them for 3" axle tubes, as well as all of the stock Mustang sizes.
  20. Russco
    Russco
    from Central IL
    I got these from Speedway Motors. I had to modify the shock mount a little but they worked well. They also have a provision for a sway bar link if you need it.
  21. Bigcheese327
    Bigcheese327
    Thanks guys. It was a bit of a worry that all of the aftermarket ones are set up for wider springs, but it sounds like that's not a problem.
  22. bengeltiger
    bengeltiger
    Falconizer your rattle can build continues to impress!
  23. MUNCIE
    MUNCIE
    from Houston
    Found on the net......looks bad @ss.
  24. MUNCIE
    MUNCIE
    from Houston
    Here is a shopt of mine with my grandosn at the wheel.He loves to come outsdie with me and work on my car. He is always asking are we going to work on the car today.
  25. 1971BB427
    1971BB427
    from Oregon
    I'm also running an 8.8" out of an Explorer, and have the 3.25" axle and set up for wider springs. Since the center pin on the new springs still keeps the springs centered I used the wider Explorer spring plates. But I cut 1/4" flat bar and tacked it to my spring plates on each side of the spring to take up the space. Not sure that it's really needed, but I felt better about not having the gap on each side.
  26. gimpyshotrods
    gimpyshotrods
    Shipping weight shows 53lbs. That's two.
  27. falconizer_62
    falconizer_62
    haha, thanks man. a little bit of spray paint goes a long way...;)
  28. hotroddon
    hotroddon
    pair
  29. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I somehow managed to puke the torque converter seal on the AOD that my trans guru built for me, although I can't imagine how I did it....:rolleyes:
    Anyhow, while it at the trans shop I figured I'd annoy my buddy and install this in the car while the trans was on the bench:
    Thanks to Virginia HAMB'r B/GasFalcon, I also got all the stuff to delete the column shift:
    Note the new harness I made to go from the cars old harness connectors under the dash to the shifter mounted neutral safety/back up light switches...
    I figured it would be easier to wire the neutral/back up switches on the bench:
    There's more commin' :D
  30. woodbutcher
    woodbutcher
    :D Now that`s a really sanitary install.
    Good luck.Have fun.Be safe.
    Leo
