Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. Hotrodbuilderny
    Hotrodbuilderny
    Nuts inside the sail panels headliner
  2. newfalconowner
    newfalconowner
    from NS Canada
    i felt that way when i was doing my MII,, so i did a full frame and braced :)
  3. Ghostcruiser
    Ghostcruiser
    from NE Florida
    I don't know, BC, but I dang sure wished I could find a new gas tank for a panel/station wagon a helluva lot cheaper than 250-300 bucks....I've seen the sedan versions available all day long for around a 100 smackers...it's discrimination, I tell ya! :D
    Rob
  4. Bigcheese327
    Bigcheese327
    Yeah, i'm real glad I don't have a wagon or Ranchero. I did hear that the rear tank off '70s or '80s F150s is supposed to be close.
    -Dave
  5. falconizer_62
    falconizer_62
    Let us know what you end up doing for the filler neck. You have got me curious now. Thanks for the heads up. I guess that my wagon gas tank may be worth something on eBay. I will try not to damage it anymore...
    ... I miss working on the wagon...
  6. Ghostcruiser
    Ghostcruiser
    from NE Florida
    Thanks for the tip, Dave....I'll check that out!:D
    Rob
  7. Bigcheese327
    Bigcheese327
    From:http://www.tffn.net/phpBB3/viewtopic.php?f=25&t=3829&start=0
    -Dave
  8. Ghostcruiser
    Ghostcruiser
    from NE Florida
    Thanks, Dave...that's great stuff! :D
    I've been a member over at TFFN for a while, and you know, I never thought to search the archives! Doh! :eek:
    Rob
  9. falconizer_62
    falconizer_62
    I haven't actually worked on the car for a while, because a few other projects came up and jumped the line. One of these projects is getting the roadster back on the road. :D
    So the roadster went into the garage, and the wagon went into the carport. This is the first time in probably three years (maybe more) that the wagon has been off of the jack stands and out in the driveway. There was some air trapped in the rear bags that I could not remove without a battery, so the rear will come down another 2 inches. Other than that, it was great to see it outside and add an entirely new angle.
  10. Ghostcruiser
    Ghostcruiser
    from NE Florida
  11. newfalconowner
    newfalconowner
    from NS Canada
  12. woodywagon1965r
    woodywagon1965r
    Hey just a thought ..
    dont like my gas cap out the side of my wagon any ideas on changes did get all the back end stuff from a cougar and thought of out my lic plate but tank sits way too high and wasnt sure of dropping the tank down a bit ...first thought was of pintos and there tanks
    did think of inside the car at the back with a fuel cell and trap door ..but means dropping the tail gate at every fuel not sure if i like that idea either
  13. falconizer_62
    falconizer_62
    I am going to make the rear tail light open and fill from inside the left rear quarter...
  14. woodywagon1965r
    woodywagon1965r
    Sounds good any idea on how pics would be great ..sorta like 56 chev
  15. falconizer_62
    falconizer_62
    I have no pics as I have not done it yet. I have, however, spent a fair amount of time thinking about it already :).
    The tail light/gas door would need long curved hinges so the light would swing away from the body. On the round bodies, there are two lips of metal in the tail light socket. I would cut the inner ring out to provide easy access to the filler neck located beyond. The pull release would be just behind the bumper. I would build a small compartment around the filler neck and vent it to the outside so that gas fumes don't buildup inside the quarter panel. Attached to the hinge would be a ring that the tail light bolts to. The pull and latch mechanism I will probably scavenge from a late-model in a wrecking yard. I would also probably use LEDs in the tail lights...
    any other ideas?
  16. woodywagon1965r
    woodywagon1965r
    Damn sounds good ...fabricatin and thinkin hat on..... this i gotta try
    car would look so sweet with out that ugly ass gas cap hanging there
    an spillin down the side of car every time you launch
    lol mac tac aint easy to put on you know and it melts with gas
    keep me informed will ya
  17. falconizer_62
    falconizer_62
    I always hated the gas fillers on Falcons. The lines are great once you get rid of the cheap touches...
  18. FritzTownFord
    FritzTownFord
  19. Kustom Komet
    Kustom Komet
    The spring tower vs. M-II thing will never die. There have been a few failures of certain parts, but there are also thousands of Falcons, Comets, early Mustangs, etc running around out there with no failures, everything still solid. There are many different kits out there of various prices and quality, and there are hack installers that don't know what they are doing. Good kit + good installer = safe car. Same as anything else chassis related. As to the safety of doing away with the spring towers and welding the cross member to the subframe rails, (reinforced, because hopefully you installed the frame rail surrounding/boxing plates which make the whole thing much stronger) how do you think a Pinto or Mustang II was built? Look at one someday.
    -KK
  20. j.r. Nice
    j.r. Nice
    I'm not an engineer. I understand what the other posters are saying.....but I tend to agree. I had mine (boxing plate/crossmember/engine mounts) tig welder by a certified welder and he welded them in completely. I also installed frame ties, so it's solid. I dont see alot of flex.
    I recently did a resto on a full size Bronco 4wd with a 3 sided (unboxed) frame. The stripped frame, by itself, was incredibly flimsy. I could stand at the back and twist the rear rails and see the flex. Much of the rigidity obviously comes from the drive train and some from the body shell. Cant imagine its much different with the unibody. I am not going to race the car, and if I were, it would have a cage.
  21. woodywagon1965r
    woodywagon1965r
    Have a Question for 1965 falcon wagon owners
    looking for biggest tire combo i can go without cutting car
    best i have done to date was a 245 60 14
    now just running 70s on it... but want to go 15 inch rims
    has anybody done a 255 60 15 if so what rim and backspace
  22. chrisclarkcustoms
    chrisclarkcustoms
    from las vegas
    Done living...
  23. kenagain
    kenagain
    from so cal
    Hey I have a question for you guys will a 62 v/8 trans fit a 63 6 cyl 170 or is the bell different? this trans is the 2 speed out of a 221 fairlane and I have a friend that needs one for a six in a 63 ranchero any help appreciated on this
    thanks
    Ken
  24. Boones
    Boones
    from Kent, Wa
    falonizer, your wagon is looking good. I must have missed what motor you put in it. I also like the strut tower and bars
  25. Square
    Square
    from Canada
    I was totally flaccid... Awesome build!
  26. falconizer_62
    falconizer_62
    Thanks man. :)
    The motor is a 3.9L (238ci) OHC crossflow from an Aussie Falcon...
  27. rocketsam
    rocketsam
    from Phoenix,AZ
    Ok i cant find the specs to adjust the heads on my six banger. its a 170,but i cant find the specs for the damn thing anywhere? does anybodys know? one more,i drove my bird the other day after the hole rebuild and it drove pretty nice,the only thing that im wondering about is the rubber stopper that the upper control arm hits. its about a half an inch away from it haha anybody else have this problem? if so, what did you do? or should i just leave it alone? -Sam
  28. woodywagon1965r
    woodywagon1965r
    No body running big tires and wheels on a 1965 falcon wagon come on someone ..maybe i should just move the springs inboard and get a 275 60 in there
  29. newfalconowner
    newfalconowner
    from NS Canada
  30. woodywagon1965r
    woodywagon1965r
    lol ya but dont want to cut the car..will however move springs if i have to but would rather not
