dollar bill test
Discussion in 'The Hokey Ass Message Board' started by ykp53, Nov 23, 2010.
  1. bobss396
    bobss396
    No doubt, you should be able to hear it at the tail pipe. But its an old trick I saw used 35 years ago by a real old time mechanic and it appeared to have worked when I saw it done.
    Bob
  2. BigBlockMopar
    BigBlockMopar
    It's so simple guys,
    if the dollarbill gets ****ed back in the exhaust the car's telling you you need to put more carburators on as the engine wants more air and now tries to get it through the exhaust... :rolleyes:
  3. Blue One
    Blue One
    from Alberta
    Whats a dollar bill ? :D Somehow a Loonie just doesn't seem to work :)
  4. chaos10meter
    chaos10meter
    from PA.
    OK what's a Loonie ?
  5. Blue One
    Blue One
    from Alberta
    Canadian dollar coin, where you been hiding :D
  6. CharlieLed
    CharlieLed
    We used to do it years ago to check for leaky valves/stuck lifters. Don't work worth a damn now since most cars have crossover pipes in the exhaust system...exhuast will constantly pulse in this configuration.
  7. budd
    budd
    maybe you need to try a toonie
  8. burnout2614
    burnout2614
    I always thought that test ranked down there with a white tailpipe meaning a perfectly tuned engine! peace
  9. lothianwilly71
    lothianwilly71
  10. Retro Jim
    Retro Jim
    I don't get the $1 bill past the gas filler tube fast enough to check to see if it would go up the pipe ! I goes up the gas filler tube damn fast , that's for sure ! :eek:
    Retro Jim
  11. Snegrah
    Snegrah
    from Pacifica
    You guys crack me up. Some good humor here. Made me forget about some "head noise" for a while....keep it up!
  12. nutajunka
    nutajunka
    Seen it done years ago, but in a different way. You start the car, then hold a dollar bill edge wise, with your index finger and thumb of both hands. If the dollar just ruffled in the exhaust stream everything was ok, if it snapped the end like a towel, then you knew you had a mis-fire. Kinda crazy when you can hear and feel a mis-fire to begin with.
  13. 57Custom300
    57Custom300
    from Arizona
    That sounds like something we use to do after a few too many, then argue about it the rest of the night.
