Dolly Towing My Roadster
Discussion in 'The Hokey Ass Message Board' started by 345 DeSoto, Mar 17, 2011.
  1. If I tow my Roadster with the front wheels in the Dolly, do I need to disconnect the drive shaft? The rear is a Ford 9", and the transmission is a 200-4R. This would be about a 1,200 mile tow. Thanks, guys...
  2. brokenspoke
    brokenspoke
  3. Bob37
    Bob37
    For that distance, I would definitely remove the drive shaft.
  4. Alex D.
    Alex D.
    from Hydes, MD.
    I have flat towed a few times without disconnecting the driveshaft without any problems. I can’t see there being any difference than coasting downhill.
  5. Stovebolt
    Stovebolt
    Unless the auto has a rear pump, I'd disconnect the driveshaft
  6. Verminator
    Verminator
    Definitely ---- 10 minutes for peace of mind??? Hmmm......
  7. Atwater Mike
    Atwater Mike
    My son dolly-towed his father-in-law's Jag 300 miles, folks were honking and pointing...he saw smoke in the rear view mirror, and pulled over...right across a field from a fire department. Dialed 911, only the Fire Dep't was not in the jurisdiction!
    Firemen stood out front of their building and watched the Jag burn to the ground. The carpet had caught fire from transmission heat...
    Son had warned father-in-law of the danger beforehand, offering to remove driveline but father-in-law didn't want him "tampering with the driveline of such sophisticated machinery". Insurance had also been canceled when 'Non-Opped'.
  8. rustyford40
    rustyford40
    from Mass Bay
    When you remove the drive shaft tape the universil, so the caps don't come off.
  9. maniac
    maniac
    I would pull the shaft and put an old yoke in the back of the trans
    Sent from my Ipad using TJJ
  10. mramc1
    mramc1
    Driveshaft should always be disconnected for a flat tow with an automatic. The ****** internals are spinning and without the engine spinning the pump the ****** will burn up. I would also suggest pulling the driveshaft if you are towing a standard ****** car on a tow dolly where the transmission is forced to work at an angle during the tow (like on a tow dolly). I towed an OT car with a T5 ****** 900 miles on a tow dolly and when I got there the ****** was hot and stuck between gears. I think the front bearings were starved for oil and burned up. I had no idea anything was wrong until I fired the car up to get it off the dolly and couldn't get it into reverse or 1st. I usually just drop the rear u-joint out of the rearend, tape the caps tight and wire tie the driveshaft under the car. Having a spare front yoke is a good idea as then you can just pull the driveshaft completely and chuck the extra yoke in to keep the ****** from puking out the tail housing.
    Josh Quick
    Quick Speed Shop
  11. dadseh
    dadseh
    dont worry about it, you'll be fine! .....
    just dont go over 30 mph!!! lol
  12. Ratroddude
    Ratroddude
    Well, how sophisticated is it now....:rolleyes:
  13. Peace of mind? Priceless
    New transmission? $$$
  14. Toner283
    Toner283
    Maybe I'm a bit redneck but I would have tried to tow the jag closer to the fire dept.
    And yes, definitely remove the driveshaft if towing for any distance.
  15. rustyford40
    rustyford40
    from Mass Bay
    I think burning Jags is a good thing
  16. dragwillys
    dragwillys
    i did when i towed my model a to florida from nj...also had my t-bucket shrink w****d by a guy that came to my home fo 60 bucks
  17. Hnstray
    Hnstray
    from Quincy, IL
    I second this advice. I had flat towed a manual trans OT car with no problem about 900 miles round trip. Subsequently, I tow dollied the same model car, also manual trans, and locked up the ******, even though it was in Neutral, in less than 80 miles. I theorize the elevated front of the car caused the lubricant to migrate to the rear of the case and starve the front area rotating parts
    It is absolutely imperative that any modern automatic be disconnected from the driveline to avoid damage unless it has a re-circulation pump installed or the engine is running at the time. That in itself is a very bad idea for several reasons.
    Dropping a driveshaft is very, very little effort when compared to the alternatives.
    Ray
  18. no mice just rats
    no mice just rats
    from missouri
    you could always put it in neutral and just leave it run...for the whole 1200 miles.
    j/k always pull the shaft
  19. 48 Chubby
    48 Chubby
    A friend of mine runs a transmision shop he has a ton of red plastic "cups" that ******s are shipped with. Go ask, most shops will give ya one. It aint heavy enough to shake out like a yoke often will.
  20. 28 chevy
    28 chevy
    from NE Pa
    I bought a driveshaft that has a disconnect, like a yolk that disconnects the rear. Can't remember where I got it but will look if you PM me. Just pull the lever under the seat and tow. Will be flat towing mine.
    Jim
  21. Dreddybear
    Dreddybear
    I towed an A pickup on a dolly from Seattle to Socal. Definitely without question disconnect the driveshaft.
  22. brad chevy
    brad chevy
    Pull the shaft and cover the tailshaft of the ****** to avoid losing fluid,these guys saying its alright to tow with driveshaft in on an auto ****** definitely don"t know anything about cars.
  23. plym_46
    plym_46
    from central NY
    suppose you could load it back***wards and secure the steerig wheel, but its probaly alot easier just to remove the D shaft.
  24. duck279
    duck279
    from SC
    rented uhaul that you can load car onto entire trailer for $50.00 a day. thats the way to go if you have access to one
  25. Hnstray
    Hnstray
    from Quincy, IL
    There was thread on this recently and towing a vehicle backwards IS A VERY poor choice of the available methods.
    Ray
  26. harpo1313
    harpo1313
    from wareham,ma
    dont forget to index your shaft with a majic marker,also wire you spare yoke to the ****** mount.
  27. rainhater1
    rainhater1
    from az
    The disconnect is made by REMCO and used by RV'er to tow 4 down, very good and have been around for ever. Never heard of anyone having trouble.
  28. Voh
    Voh
    Spend the $60/day and rent the uhaul car hauler. get it off the ground.
  29. phukinartie
    phukinartie
    In the time it has taken me to read this thread I could have removed the driveline :p
  30. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Call around and find a trailer at one of the rental places, in the long run you will be much better off. 1200 miles is a long haul!
    Better safe than sorry in the long run!
