Dolphin gauge install help..
Discussion in 'The Hokey Ass Message Board' started by Al, Apr 23, 2009.
  1. Al
    Al
    from Duluth, Mn
    I have a set of Dolphin cluster gauges for a 37 Ford. They fit the dash the way they should. My problem is with the senders.. I have a Holley Street Dominator intake on a 350 sbc. They sent with the kit a couple of br*** fittings, and the temp sender its self. The br*** fitting that should screw into the intake is to large.. Can I get a new fitting at a auto parts store?? The sender screws into that fitting.. My other problem is with the oild sender unit. It also is electric. It looks like a small tank. There is still a small fitting on the back of the engine where a manual tube may have been.. I can unscrew that fitting, but I am not so sure that that tank will even fit. The tank its self is to big. It will either hit on the intake, or be way to close to the distributor.. The instructions tat came with the gauges doesn't say anything about the sender units.. Thanks.. Al
  2. zman
    zman
    from Garner, NC
    Those gauges are pretty much the bottom of the barrel. I will NOT install them in a customer car at all. To many issues with them. You should be able to get any adapters you need from a decent parts store though.
  3. Royalshifter
    Royalshifter
    Moderator
    I know I'm not helping but aren't those guages ugly and not ever work properly?
  4. choppintops
    choppintops
    You just need to get an adapter fitting for the temp sender. For the oil, most often it needs a 1.8" inch pipe extention, then a 45 or 50 degree adapter.
  5. enjenjo
    enjenjo
    from swanton oh
    Make sure you use a steel pipe and elbow for the oil sender, br*** will break from vibration, don't ask how I know.
  6. Al
    Al
    from Duluth, Mn
    If I were to get other gauges.. ( not saying I will or not) What would be a gauge cluster to look for?? I need both the Volts,Fuel,Oil and a Speedometer both 5"..
    Otherwise I will get the STEEL pipe fittings and elbow..
  7. Cl***ic Instuments are good quality, or older SW's.
  8. choppintops
    choppintops
    Just run the Dolphins, you already have them. They aren't the best quality, but MANY cars out there have them.
  9. X38
    X38
    mmm ...Dolphin.
  10. Al
    Al
    from Duluth, Mn
    I like the looks of them.. That's why I bought them. Paid $225 for them. Like choppintops said.. I have them now.. I might as well use them.. I will check at NAPA for the parts that I need.. Al
  11. 34P
    34P
    Hi Al, So much for help with Dolphin gauges huh? Why ask a question here when all one gets is put downs? I know this is more than a year later but my Dolphin gauges have worked fine for longer than that and look fine too. I just put in a new gas tank and the fuel gauge is acting funny so I will go to a site that is helpful to people with questions regarding cars.
  12. Evilfordcoupe™
    Evilfordcoupe™
    Whatever you do, dont ever let a dolphin ****ly penetrate you, it will kill you.
    -Jason
  13. zman
    zman
    from Garner, NC
    Read This First! then do your intro, then come back and *****... otherwise don't let the door hit ya.... :p
    Smokin Jeff likes this.
  14. O, those three little letters, fng...
    Soapboxing without an intro on a 2 year old thread- gotta love 'em :)
