Domino effect
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Mar 17, 2013.
  1. HOTRODPRIMER
    HOTRODPRIMER
    you guys know how it works,,the old chain reaction that occurs when a small change causes a similar change nearby, which then causes another similar change, and so on in liner seaquence.
    I had recently ordered a original p***enger side window regulator for my sedan from **** Spadaro to replace the bad one that was in the car.
    Yesterday afternoon I took every thing loose and installed the new regulator,,lined up the window channel and checked the window by rolling it up and down,,,damn,its binding.
    Took everything out checked the gl*** to make sure it would slide in the window felt and discovered that it's not the gl*** but the felt had come loose at the bottom and wadded up.:mad:
    So now I got to hurry up and wait until I get the replacement,,,
    Is it just me or is this type of thing that plagues us all? HRP
  2. That's how ground up restorations and builds start.
  3. diegochero
    diegochero
    Operation snowball in full effect.
  4. Mike51Merc
    Mike51Merc
    While I'm here fixing this I might as well..... replace everything.
  5. blowby
    blowby
    from Nicasio Ca
    My rear axle was too wide and I couldn't find any wheels to fit inside the fenders. So I bought a narrowed 8". That required a new drive shaft so I decided I might was well go to a T5 trans. As long as I had to build a new cross member I decided to move the engine back an inch. As long as I had the hood and fenders off I decided to relocate the front suspension. At the moment it sits with no rear end, no front end, no trans and engine dangling.
    I should have looked harder for wheels...
  6. Pscott
    Pscott
    :p Haha, sorry blowby just had to laugh. You should name the car Domino or Snowball now.
  7. Fenders
    Fenders
    THAT is cl***ic !!!
  8. DRD57
    DRD57
    All the time. Add to this the fact that the vast majority of aftermarket parts don't fit without some modification.
    Some of the reasons everything takes longer and costs more than expected.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    This in a lot of cases is what causes a runner to become a for-sale dead project for 1/2 the money the car is worth.
  10. sidevalve8ba
    sidevalve8ba
    HRP,
    I went to change the bed on my avatar. The fabbed bed on it had a raised floor. So to mount the bed with the floor at original height I have had to move my battery box, the horn(?), change the exhaust and lower the gas tank. Other than that it practically bolted on. :rolleyes:
  11. tommy
    tommy
    I just fixed the gl*** runner in the drivers door. Believe it or not I was able to re use my old one after I straighten it. I said what the heck and tried to do it. Be very afraid of the "whileI'ma***s" be very afraid.:D
  12. 56don
    56don
    Danny, the exact thing happened to the coupe when I was putting the regulators in it. You can never fix just one problem at a time anymore it seems. Every small project I undertake seems to change something else and that needs to be addressed and so on an so on and scubby dooby do on.............
  13. blowby
    blowby
    from Nicasio Ca
    And then there's outside forces. I hoped to make some progress this weekend however yesterday the wife was doing laundry when the washing machine started banging and walking around on the spin cycle. Drum bearing went out and darned if I'm going to spend hot rod money on a new machine. So today I get to tear that apart instead. Usually it's the daily driver that conks out right in the middle of another project.
  14. onedge
    onedge
    How true it is. Fun with old cars.
  15. ClutchDumpinDan
    ClutchDumpinDan
    Somehow this started as a worn out steering box. I've given up trying to figure out how it happened...
  16. Rocky72
    Rocky72
    from Pa.
    I'd start telling you guys how it goes for me but the internet isn't big enough to put it all here.
  17. HOTRODPRIMER
    HOTRODPRIMER
    Having just finished get the windshield frame back in the car after taking way more time than it should I was thinking this will be a easy hour or so fix,,famous last words! :D HRP
  18. A few years back a guy brought me a 36 ford for a little wiring, and a couple floor patches.
    A year and a half and $70,000 later he drove away.........happy!
  19. hombres ruin
    hombres ruin
    It seems that everything in an old ride is linked together.When one thing small is found to be wrong it has reprocussions on ten other things.Remember the ****er fly effect,the ****er fly beats its wings one time and cause a chain reaction of events around the world..or something like that
  20. hellsgaterods
    hellsgaterods
    I think its called "hot rod builders law" to fix one thing, you must fix ten more
  21. Greezy
    Greezy
    This is exactly why I sold my 40 coupe after the crank broke. I knew one way or another it would have resulted in a complete redo of the car.
  22. atch
    atch
    i feel your pain:
    clarence; autumn of 1991:
    removed the 239" flathead/3sp to install a 283/pg
    found broken right front mainleaf
    decided "while i''m at it i'll subframe it"
    investigated front suspensions and decided on aspen/volare
    started changeover & discovered that original steering column would be hard to use
    bought tilt column
    while at the boneyard bought a pair of bucket seats
    went back to installation
    decided that since i'm changing the front lug pattern to 5 on 4.5" i might as well change rear also
    bought mustang 8"
    obviously had to have different driveshaft so found one at boneyard that fit with no modifications
    etc.
    etc.
    etc.
    had it back on the road by 1992 springtime driving season and maiden voyage was to nsra nats in louisville
    would i do it over again?
    you bet; in a heartbeat.
    b-t-w; for you out there who criticize the switch from (running) flathead to sbc: the flatty is still on the stand and might get used in a lighter weight rod down the road. the 283 barely can get out of its own way; the flatty didn't have ANY get-up-and-go at all in a panel truck.
  23. lht
    lht
    yea my luck is so bad it could be rainin ***** and i'd get hit by a hard ****
  24. HOTRODPRIMER
    HOTRODPRIMER
    Like the old joke goes,,Damn, if I would have told that!:confused: HRP
  25. Merlin
    Merlin
    from Inman, SC
    Danny If you haven't ordered one yet call me I have a whole door set here.
  26. HOTRODPRIMER
    HOTRODPRIMER
    No Harry,, I haven't ordered yet,,I'll shoot you a PM. HRP
  27. bobss396
    bobss396
    To quote my dad, "sometimes you have to jack up the radiator cap and slide a new car under it.".
    Bob
  28. Boyd Who
    Boyd Who
    When I took my Es*** apart two years ago the plan was to simply replace the engine & trans and get it back on the road. Two years later the only stuff I kept were the sheet metal and the bare frame rails.
  29. SchlottyD
    SchlottyD
    Get this, I bought a 28/29 model a cowl top and tank in February now I'm buying a car that needs it. Hows that for domino effect?
  30. Its because all cars have Six degrees of separation from a previous owner named Murphy.
