Don't Ask Me How I Know...
Discussion in 'The Hokey Ass Message Board' started by Benzine440, Jan 9, 2005.
  1. lownrusty
    lownrusty
    Dont ask me how I know? Dont leave a breaker bar with socket attached to bottom pulley, and trying the starter!! [​IMG]
  2. jonnycola
    jonnycola
    Dont ask me how I know that dried methelyne chloride paint stripper, when sanded, will make it through your dust mask and into your throat and lungs, causing second degree burns.
    Dont ask he how I know that wearing a loose fitting cotton glove while working on a very large belt sander can put you in major pain, as well as the hospital with a bone infection. Apparently bones shouldn't be exposed to the open air and metal shavings.... who knew?
  3. long island vic
    long island vic
    sont ask me how i know that when you take a big slug from the beer can that you used too drain the cam 2 into i will not quench your thurst
    lothiandon1940, treb11 and trollst like this.
  4. loogy
    loogy
    Don't ask me how I know that that you can be pulled UNDER the workbench by a running, gaurdless air compressor. I dropped a wrench under the work bench. When I went to retrieve it, the loose sleeve of my sweatshirt got caught up in pulley of the compressor, yanking me completely under the workbench. Of course the sleeve kept twisting more and more with each revolution of the pulley until it became a tourniquet finally tripping the breaker. Home alone, not able to free myself from the comressor (which is bolted to the floor) I feel around on the workbench with my free hand for something to cut away the sleeve with. The only thing that I came up with was a file. It took a little while, but it worked. Guard went back on the compessor the next day.
    Don't ask me how I know that you can burn about 2" off of a persons forehead (and the eyebrows and the eyelashes) while trying to dry a freshly painted exhaust system with a torch. (fumes inside the tube ignited at just the same moment as my friend walks by the open end, AND he had a date that night)
  5. Cris
    Cris
    from Vermont
    Don't ask me how I know that you can't subs***ute power steering fluid for brake fluid in an emergency. Don't ask me how I know.
  6. Thirdyfivepickup
    Thirdyfivepickup
    Don't ask me how, but apparently, if you were to drop a screwdriver while working on your Ford... your stick shift Ford, which is in gear... Then that screwdriver were to get wedged against, lets say, the starter solenoid, for example... connecting the 'magic terminals.'
    I'm told, that the little Ford will fire up and idle away.
    Allegedly. [​IMG]
  7. Sport N Woode
    Sport N Woode
    from Middle TN
    Don't ask me how I know that using drywall on one wall of the garage to stop a suddenly un-compressed coil spring coming from the other side of the garage will not only create a new "window" of opportunity but also a very nasty visit from the soon-to-be-ex-wifey. Don't ask me how I know.
    Even after learning that much needed bit of knowledge, don't even think about asking me how I know that trying a somewhat different approach to coil spring removal only ended with a completely distroyed oil pan. This is when I suddenly learned how to read. [​IMG]
    Butcher
  8. PrimerDust318
    PrimerDust318
    from NOR*CAL
    No matter how much you jump up and down on a lug wrench and curse "Lefty-loosey, Righty-tighty" does NOT apply to any lugs on a Mopar stamped "L" DAMHIK.
    Also, A long oil filter will NOT clear a small block A Body Mopar's torsion bar on the way out without a chest full of hot oil. DAMHIK
  9. hollywud
    hollywud
    Dont ask me how I know,But if your car is equipped with air bags.Make sure your feet are clear while SHOWING OFF at a cruise night.Theres something about that pesky PANCAKE switch that Really hurts.Yhe funny thing is,You instantly forget which switch does what. [​IMG]
  10. Don't ask me how I know...
    but if a guy were to overfill his floorjack, and put the little rubber plug back in the hole, and then stand directly over it and stomp the jack down, the resulting guyser of hydraulic oil will fill your sinus cavity to it's maximum capacity and push your eyes from their sockets.
    Just... Don't ask me how I know...
    JOE[​IMG]
  11. Christiana56TS
    Christiana56TS
    Don't ask me how I know that hearing your motorcycle-only building friend say "What does this do?" while he reaches for the ****** linkage will have you chasing your car down the driveway... Also, don't ask me how I know catching said car leaves bruises all over your legs (thank God the door was open)... To say nothing of the hurt feelings when said friend is banished from your garage...
  12. Jeffie James
    Jeffie James
    here we go...
    dont ask me how i know, that jackstands serve a perfectly meaninful purpose. just because you dont think u have enough time between burnouts to use them. single piece o **** jack under rear, lugs loose and removed, gravel uneven surface, and BAM 2 seconds later youre trying to figure out how to, 1) get your hand out from under the license plate 2) keep evrybody at the fairgrounds from staring at you 3) reattach the rear fenders to the car, (seeing as how the wheels were still on the rear) and then apologize to the owner of said vehicle.
  13. dadseh
    dadseh
    Dont ever ask my good friend how he now knows that a freshly painted and still wet radiator will, when dried in front of an electric bar heater, burst into flames from the trapped solvents in the finned area. And, create its own wind tunnel effect <font color="red"> </font> as air is drawn through the fins to further enhance the flames bursting forth.
    DadsEH
  14. Nailhead A-V8
    Nailhead A-V8
    don't ask me how I know that towing a collector car from the rear with rope and a bungie cord on the steering wheel while turning your head to look forward for 1 second will result in the car turning side ways and T boning the car into your back bumper crushing the 1/4 panel
  15. hotroddon
    hotroddon
    Don't ask me how I know, but if there is an almost 12 year old thread on the HAMB, someone will post on it
    lothiandon1940 and Bandit Billy like this.
  16. hotrodA
    hotrodA
    Now this is some funny ****, no matter how old! Makes you cringe, and then laugh hysterically. More, more, more!
    lothiandon1940, wraymen and Slopok like this.
  17. trollst
    trollst
    Well, I DO know now that storing batteries on the workbench and grinding two feet away can cause bad things to happen........as well as one hell of a mess to clean up. Both in the shop and in your pants.....ask me how I know.....
    lothiandon1940 likes this.
  18. slack
    slack
    This has got to be the funniest thread on the HAMB.:D
    And I thought the purple hippo was funny.o_O
    Slopok, slim38 and Jet96 like this.
  19. slim38
    slim38
    from Sudan TX
    Dont ever air your tractor tire with propane and months later take it to a local welder so he can weld small crack on the rim and not warn him about propane. Happened to a neighbor. Killed the welder and left a huge hole in the roof.
  20. Slopok
    Slopok
    Don't decide to take a leak while in the midst of removing paint from a vehicle with Aircraft paint stripper without first washing your hands really good! Some parts of your body are way more sensitive than calloused hands.:eek:
  21. Slopok
    Slopok
    That's what I thought until post #79.
  22. i.rant
    i.rant
    Don't ask me how I know but if you're ever interrupted while changing your oil check to make sure the drain plug is in BEFORE pouring 5 quarts of oil in the engine.:confused:
  23. slack
    slack
    Now, that ain't funny
    Yeaho_O..........that's exactly what I thought...............we had a good run:oops:. Who airs a tire with propane? You would have to rig fittings. It would be a pain in the ***. What a buzz kill. "I cain't have nuthin nice :("
    wraymen likes this.
  24. belair
    belair
    Good judgment comes from experience. Experience comes from bad judgment. Don't ask me how I know.
    lothiandon1940, Baumi and slack like this.
  25. mountainman2
    mountainman2
    this thread does raise questions about the ***ertion that the HAMB has some of the smartest people in the automotive hobby. Not that we don't have them but that many of their "smarts" were earned the hard way.:eek:
  26. vtx1800
    vtx1800
    Don't ask me how I know that you shouldn't walk around in the dark even when you know the area "fairly well". I had spilled some grease out of the transmission while changing the "bullet" speedometer gear in the four speed and after cursing myself for spilling so much I mopped it up and trundled it out to the burn ring so it would be in the shop. It's almost pitch black near the burn ring so I very carefully shuffled out, found the burn ring and dumped the oily rags. I turned and walked a couple of steps and went right over the steel bench that I'd just fixed and the only thing that hit was my head on the bumper of my daughters dead player car. The gash on my eye brow bled a lot, my neck was sore from all of the vertebrae cracking when I hit but I thought that was it. A couple of weeks later I found that I must have had a concussion because I had a trip to the ER, a CAT scan and a MRA (Like an MRI except of just the blood vessels) three doctor offices calls and lots of pain pills.
    So.. trust me, don't walk in the dark!!!!!
  27. kidcampbell71
    kidcampbell71
    .... don't ask me how I know. HAMB so bad *** in 2005, that it took me 7 years to join and I still hesitate to post even to this day of the talent that drew me here. For I am still a 'schmuck. Don't ask me how I know.
  28. wraymen
    wraymen
    #79 was definitely a buzz kill but bttt anyway.
    Don't ask how I know that deciding to go out and work on your car after a few drinks is a bad idea.
    Don't ask my buddy that after making it home on your bike before a rain storm you decide to throw a plastic cover over it to keep it dry. The original shrink wrap.
  29. iwanaflattie
    iwanaflattie
    Don't ask me how i know that 2 new power steering hoses with the newer ORing fitting wont fit on an older steering pumpp.
    that grinding the fitting down to make it fit on the pump just for "mock up" thinking that u can go to a hose shop that can press a fitti g for 10$,
    Instead a f######n $11 hose turns into a $51 because the hose shop needs an aviation engineer and a government official to approve this fitting.
    So DAHIK grinding the Oring fitting costs 3 hoses and a trip to the junkyard for a new PS o ring inlet fitting.
  30. DeanH
    DeanH
    Top this: Don't ask me how I know that you should always double check your dates before heading to Bonneville. Back in the '90's my brother and I drove 3,000 miles to stand and stare at the bare salt (ala Chevy Chase in Summer Vacation)!
    charleyw, kidcampbell71 and wraymen like this.
