Technical door handles -32 5w
Discussion in 'Traditional Hot Rods' started by 3wmike, Apr 29, 2023.
  1. 3wmike
    3wmike
    Hi
    What is the problem here, the handles box said Vintique Inc. handles nr: B-702350/1-L and what I can see it should be suitable for a 5w coupe, but there is a lot of misalignment
  2. krylon32
    krylon32
    from Nebraska
    Henry body and latches? I've always used Drake handles which fit good and have no experience with Vintique. Maybe they're made in the same place?
  3. 3wmike
    3wmike
    I have a UP body
  4. Anderson
    Anderson
    From my experience with the products of both companies, I believe what you’ve got is bad parts that don’t fit other bad parts.
  5. krylon32
    krylon32
    from Nebraska
    I've only had 1 UP body but the Drake handles fit perfect.
  6. deuceman32
    deuceman32
    I would agree with Krylon32 that the Drake handles would be a better bet. Vintiques uses die cast chrome plated outsde parts for this application. Drakes handles are ***embled from stamped stainless very much like originals, and yes they cost more. With the stainless bezels you could slightly shape or trim a bit I would think.
  7. 19Eddy30
    19Eddy30
    from VA
    Original 32 5w,
    Is yr door Gl*** or steel?
    I had Vintique with no issues, I just did not like the solid handle .
  8. chop&drop
    chop&drop
    I recently used the same Vintique handles on my UP 5-Window with no fitment issues. Could something in the door be the issue? Unfortunately I can’t look at mine as my car is out being upholstered.
  9. 3wmike
    3wmike
    19Eddy30 my dike is steel (UP)
    I tried to grind away material from the side it was thicker but then the axle hole didn’t fit
    The grip in the handle isn’t in 90 degrese angel against the mounting plate
  10. swifty
    swifty
    I'm with @chop&drop, UP body and Vintique handles with no problems. I did not realize the difference between Drake and Vintique but did know that Drake stuff was usually better quality. Aussie suppliers only carry Vintique, probably because of the cost..
  11. 19Eddy30
    19Eddy30
    from VA
    Is it both sides or just p*** side?
    Here is another Original,
    Make a templet out of cardboard of belt line shape as needed , or take Comp***
    Fat marker to get the shape ,,
    Use templet to shape bezel as needed.
    You should not have to do but some times it needs to be done.
    I have delt with UP stuff some need modified , just to let you know wide side up , & maybe hole stamped .125th or so to low , I have not worked with UP doors frame / skin , every other part they make for 32 5w I have ( every replacement panel)
    Outback likes this.
  12. hotcoupe
    hotcoupe
    I have some original Ford five window handles, message me if you're interested.
    Tom
  13. dlw1932
    dlw1932
    from Nebraska
    I used original handles on UP doors and they fit perfect.
  14. Illustrious Hector
    Illustrious Hector
    Pardon the ignorance here, Do 3w and 5w have different handles? I know the ones on 4 doors & sedans are different.
  15. 19Eddy30
    19Eddy30
    from VA
    3 w are different , close to being flat ,
    Roadster different also
    5 w & Todur same ,
    Some one will fill in on other models
    Outback likes this.
  16. krylon32
    krylon32
    from Nebraska
    I've used the same Drake L&R part number handles on 5 windows, 2 &4 door sedans, B 400, Vicky, no problems. I've never had a sport coupe or cabriolet but I suspect they use the same handles?
  17. Fordors
    Fordors
    Sport Coupe uses the same as 5W etc., and Cabriolet has a flat escutcheon like the 3W but the operating shank is shorter.
    Outback and alchemy like this.
  18. 3wmike
    3wmike
    When you compare 19Eddy30 photo above and mine the handles do not look the same
