Door Hanging assist
Discussion in 'The Hokey Ass Message Board' started by charleyw, Jan 9, 2011.
  1. charleyw
    charleyw
    I work mostly by myself and as a reesult damage a lot of stuff just trying to manhandle things into place. I've been needing to fix the door tops on my F-1 project for quite some time. As heavy as the doors are and having to start the bolts into floating nut plates in the jamb I just put it off. I've seen commercial fixtures for body shops, but I couldn't see spending the bucks.
    Today I decided to put something together to get the job done. I used whart I had laying around. Hopefully the pictures will be self explanatory.
    One thing I did different from the commercial units was to make the outside upright folding. That made it easier to load the door and remove the fixture afterwards.
    I'll put foam on it later to protect the finished parts. Right now it falls under the"Crude but Effective" column.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Great home brewed tool there. I've hung a few doors but used only a floor jack with a 2X4 across the saddle.
  3. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Ill second the wobbly 2x4.............
  4. 3rd on the wobble board...
  5. DD COOPMAN
    DD COOPMAN
    Used the jack method many times. I've also used a "cherry picker" engine hoist. Actually makes it easier to "wiggle" it a little bit to get bolts started. DD
  6. enjenjo
    enjenjo
    from swanton oh
    Here's mine, made out of a Harbor Freight trans jack
  7. Like DD says,,,cherry picker and a sling.
    Also use a cherry picker to hold a door for painting,, made a bracket to go in the upper channel hung on a swivel hook,,,,
  8. charleyw
    charleyw
    Understand the cherry picker method, however, I have 5 project vehicles in a 30 x 40, so floor jack is easier for me. I can't stand to leave one outside Ha Ha.
  9. Kaptain Kustom
    Kaptain Kustom
    from Finland
    I too don't have any extra space. Actually I don't even have any kind of hoist... :(
    I'll definately tinker something similar as the need'll come. Thanks!
  10. With space a problem, an ATV/MC lift might work with some supporting framework.
