Door hinges screws are rusted ?
Discussion in 'The Hokey Ass Message Board' started by Frenchy Dehoux, Dec 27, 2011.
  1. Frenchy Dehoux
    Frenchy Dehoux
    I have started to work on my 29 Briggs and I have all of the screws that are holding the hinges on both doors rusted out. I was told that you can use acetone with a mix of another liquid to let it sit a while and they will loosen up. What is everyone using other than the acetone or is this the most effective way to remove rust. Any comment is appreciated on this subject.
    Thanks
    Frenchy
  2. squirrel
    I've had decent luck with mixing acetylene and oxygen, for getting rusty screws out.
  3. slammed
    slammed
    Kroil soaking. And the afore mentioned heat.
  4. Use left-handed acetone on right hand threads.
    (I believe it's acetone and ATF)
  5. gimpyshotrods
    gimpyshotrods
    It is. 50/50.
  6. tubman
    tubman
  7. 50Poopbox
    50Poopbox
    I second Tubman
  8. Cruiser
    Cruiser
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    We borrowed that tool idea and my Son made his own version using a slotted screwdriver tip from Home Depot, and old 1/4 inch x 1/4 inch socket, and the pointed tip from his air chisel. It took him a few minutes to weld it up and it removes frozen screws like ****er. All you have to do is let the air chisel shake the hell out of the screw for a few seconds then turn the handle counter clockwise to unscrew the fastener. He ground a little off of the edges of the screwdriver bit so it would drop down deeper into the recessed washer model a's used, and that made it fit better.
    Whoever came up with this idea was a genius.
    Don
    Here is the tip you buy from Home Depot.
    And here is the setup after you weld the 1/4 inch socket to the end of the pointed chisel.
    Don
  10. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    That's pretty damn neat!
  11. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Question: Why are you removing the hinges from the Model A? I planned to leave mine alone, are they slotted for adjustment in there?
  12. dirt t
    dirt t
    Great post! Learned something new today.
  13. tommy
    tommy
    Use what ever penetrating oil that you like and give it some time to work but don't try to remove the screws with out the proper sized tip on an impact screw driver. The best under 10 dollar tool ever invented. It only takes one heavy blow to break it loose and then it's gravy.
  14. R Frederick
    R Frederick
    from illinois
    My boss showed me to just heat it up with a propane torch, then quench the srew with penetrating oil while it's hot. It will smoke a lot, but keep spraying. The oil will be drawn in like sweating a pipe fitting.
    It works, I removed some knarly nuts from trailer backing plates this way last week. Worked flawlessly without ruining anything.
  15. 56don
    56don
    I had tried all these methods before including the hot wax method.I had the best luck with the aforementioned home made tool after using heat and wax. The tool works .
  16. Frenchy32
    Frenchy32
    from arizona
    Thank You for the concern. I am taking the door to be blasted and want to remove the hinges before they get blasted. Than I will install new screws.
    Thanks
    Frenchy
  17. chaddilac
    chaddilac
    I used the same thing on my T coupe door hinges... and they saved all the threads... I was able to order the new screw package and they screwed right in no problem!!
    I started with a medium blow tightening the screw, then loosening it!
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    Words can't ever explain how easy that air chisel tool makes it to remove even the most stubborn rusted screws. It literally is like magic. The vibrations from the air chisel hammering for a few seconds knocks the rust loose, and you simply have to put a slight amount of pressure on the handle to spin it counter clockwise and the screw just turns right out of the hole...........leaving no damage to anything.
    With HF selling air chisels for less than $ 20 you can afford to waste the one pointed chisel to weld the 1/4 inch socket on. You literally can remove every screw in an old car in less time than you would have spent on just a few stubborn ones. If I hadn't seen it I wouldn't have believed it.
    Don
  19. slddnmatt
    slddnmatt
    Use the air hammer tool, I made one awhile back and damn it works great!
  20. 32v
    32v
    from v.i.
    weld a nut on it (through the middle) place wrench on nut turn it out
  21. I'VE HAD THIS IN MY TOOL BOX FOR 40 YEARS AND I STILL USED IT. IT'S WORTH IT'S WEIGHT IN GOLD. SOAK IT, HEAT IT, BEAT IT.[​IMG]
    Use what ever penetrating oil that you like and give it some time to work but don't try to remove the screws with out the proper sized tip on an impact screw driver. The best under 10 dollar tool ever invented. It only takes one heavy blow to break it loose and then it's gravy.[/QUOTE]
  22. thebronc4019
    thebronc4019
    from New Jersey
    Glad someone brought up the air chisel attachment again. I have been meaning to make one of these for the last two years. When this thread brought it up again I finally got around to it today. Took me about 30 minutes and now it is in the tool box and I am sure will come in handy sooner or later.
  23. Frenchy Dehoux
    Frenchy Dehoux
    Well I appreciate all of your ideas I am planning to make one of these tools looks easy enough.
    Thanks
    Frenchy
  24. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Ive had luck blasting the part and then backing the screws out
  25. The37Kid
    The37Kid
    I've got a '29 Briggs project on the back burner, I think the hinges are unique to that body. One half is two piece, held together with a spot weld, I drilled it out so I can gl***bead things and know I have good hinges when I start to fight alighning the doors. :)That Home Depot screw tip looks like a fine addition to everyones took box.
  26. Frenchy Dehoux
    Frenchy Dehoux
    Thank You for posting these hinges.
    Frenchy
  27. The37Kid
    The37Kid
    Glad to help. I'm still looking for a complete cowl section.
  28. tommythecat79
    tommythecat79
    Second that every one of my hinge screws were solid I just bought some cheap *** wal mart steel nuts and welded them on through the center. The heat from welding expands and contracts when cooled loosening the screws then you can wrench them right off.
