Hot Rods Door latch ‘56 Chevy truck
Discussion in 'The Hokey Ass Message Board' started by lcfman, Apr 3, 2023.
  1. lcfman
    lcfman
    from tn
    I am looking to replace the door latch/striker for my 56 Chevy truck. The oem parts are not that great in my opinion so has anyone upgraded to a better system? I looked at the Altman latch system which looks good but requires cutting into the door panel and probably redo of the upholstery. Suggestions comments welcome. Thanks
  2. squirrel
    I expect that anything you find that is not OEM for that truck, will require some metal work to make it fit. Good luck.
    I still have the original style on my 59, been replaced a time or two...lubrication is important, to make them last, and most of us neglect it.
  3. krylon32
    krylon32
    from Nebraska
    Check United Pacific. They make of this kind of product.
  4. Bob Lowry
    Bob Lowry
    On my '54 3100, after I spent some time adjusting the plates, lubed it up well, and often,
    my doors will close and latch with one finger. Before I had to slam the doors at least twice
    to get them to latch. My experience has been very good with the original equipment, but
    I understand where you are coming from.
    squirrel likes this.
  5. 38Chevy454
    38Chevy454
    If you want some bear claw type latches, I can help you out. But you will have to do some cutting and fabrication work to install them. www.hotrodlatches.com
  6. Roothawg
    Roothawg
    I am planning on using the Altman latches. I think it's worth the effort.
  7. 40Vert
    40Vert
    I used the Altman latches on my 56, my old striker plates were worn to the point of not holding and the repops were not good. Loved tje Altmans. Pretty straight-forward install.
    Roothawg likes this.
  8. Roothawg
    Roothawg
    Bob Lowry likes this.
