COE Door Pins?
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Jun 9, 2015.
  1. wetskier2000
    wetskier2000
    from NH
    Anyone found a source for replacement door "pins". These go into the hinges to join the two halves of the hinge. They have a raised, section near the head. I need them for the 41 Ford, but suspect others might be similar in that vintage.
  2. verde742
    verde742
    Wescott's in Damascus, Oregon. betcha they got'em
    1-800-523-6279.
  3. wetskier2000
    wetskier2000
    from NH
    Yup. he had them! thanks! Of course, he asks do you want the long ones for mirrors? I reply with "uhhh, I haven't gotten that far in the build, just send me the short ones".
  4. verde742
    verde742
    Yep, pretty darn competent, ya think ? Be sure and have them enclose a catalog.
    you be amazed !!!!
    I was a Wescott Dealer for 28 years...
    The POP p***ed away a few years ago, on But MOM and Son are carrying on.
  5. X Aero Painter
    X Aero Painter
    Ordered from Wescott's and received. Now to get the old ones out..... Ugh
  6. verde742
    verde742
    weld up a square, say 1/2 in maybe even 3/4 in. solid stock, that will fit over hinge drill large hole in top, directly below hole, drill small hole and thread it, use stainless allen head 1/4 inch or less, depending on size of pin. taper, threaded bolt, slip square over hinge and start screwing,up from bottom, after soaking with lubricant. Tap with hammer, as you go. good luck..
  7. X Aero Painter
    X Aero Painter
    Large hole in top is so pin can rise thru and hole directly below, means on the under side of the block to thread and push it up thru? Is that correct?
  8. verde742
    verde742
    yep, your on to me,
    made mine in 11th grade shop, amazed my instructor. 54 years ago.
    don't forget to tap, even if you use a blunt chisel, I think the tapping does it: when the bolt get tight. tap then tighten , repeat.
  9. X Aero Painter
    X Aero Painter
    Will Do Thanks !!
