Hot Rods Door popper electrical question
Discussion in 'The Hokey Ass Message Board' started by 37 Dodge Rod, Oct 16, 2023.
  1. 37 Dodge Rod
    37 Dodge Rod
    I have shave doors on my 37 Dodge street rod. Since the battery is inside the car I worry about a dead battery. Some one told me that I could run a separate wire from the popper relay to a second battery. Then install a battery isolator between the two batteries so the primary battery would charge the secondary battery but would not dis- charge the secondary. Would this work?
    Thanks
    Sam
  2. 05snopro440
    05snopro440
    Just run extra terminals to somewhere accessible from the outside of the car (underneath the rear for example). Then you can energize the battery if necessary and don't have to have a second battery. You can pair it with a keyed battery shut-off for extra safety and security.
    99% of the issues I've heard of from guys I know with shaved handles getting locked out are during storage.
  3. 3quarter32
    3quarter32
    I have a cable that is not visible without hunting for it. Just a tug and the door is open.
  4. Hoptup32
    Hoptup32
    External terminals 05nopro440 mentioned using. $27 Amazon
  5. BJR
    BJR
    On my Buick I have a hidden cable that opens the doors, plus hidden power connections if the battery goes dead.
    Pist-n-Broke and dana barlow like this.
  6. Just put handles on the door.
    My wife’s last car was designed with only one way into the trunk. Key fob ****on and that’s it. What a dumb idea. No cabin ****on either.
    My new truck has only electronic tailgate, no latch and it’s absolutely dumb. Just over complicated a tailgate on a damn pickup truck.
    My buddy has shaved handles on his 34 but it’s a roadster. His trunk WAS on a popper too, had a safety cable underneath in case something went wrong. He switched it up to linear actuator with no way of getting in should they screw up without taking 1/2 the car apart.
    Nothing electrical or mechanical ever screws up, ever.
  7. 37 Dodge Rod
    37 Dodge Rod
    We tried to install a cable but it did not work. Thanks for the other reply on the external terminal.
  8. fastcar1953
    fastcar1953
    leave vent window unlocked.
  9. lostone
    lostone
    from kansas
    My dad had shaved handles on his 53 studebaker and ran a small single power wire from the solenoid to a small post under the rocker along with a small ground post
    If the battery died all he did was throw a pair of jumper cables to the small posts and a quick touch to a separate battery posts the drivers door would pop.
    With no other draw on that post but just the door solenoid he could have probably even popped it with a small lawn mower battery....
  10. stanlow69
    stanlow69
    Put both doors on separate fuses. In case one blows, you still have access to the other door. And ditto to external charging posts. I`ve installed a few on customers cars. Because they just needed them.
    05snopro440 likes this.
  11. '49 Ford Coupe
    '49 Ford Coupe
    Go to a bicycle shop and get a long segment of bulk brake line cable and run it through the door jamb up to the grill. It's important to secure the cable at the termination inside the door. I have pictures of how to do it on my website if you're interested just let me know I'll send you a link
    abe lugo likes this.
  12. '49 Ford Coupe
    '49 Ford Coupe
    In addition if the door popper issue is one of the linkage from the solenoid to the tripping mechanism any amount of additional batteries or wiring or terminals won't get the door open. I also added an additional bicycle brake cable configuration from the inside door handle so that when I pull the handle up the mechanical linkage pops the door first and then the electrical switch energizes the solenoid.
