1952-59 Ford Door rust prevention
Discussion in 'Off Topic Hot Rods & Customs' started by Kustomline54, Apr 24, 2023.
  1. Kustomline54
    Kustomline54
    Hey guys, I had the doors off my 54 Ford blasted, just the interior panel side and inside of the door bottoms. Came out clean.
    Looking to see what's a popular or trusted way to prevent rust from creeping back especially from the door bottoms.
    Thanks!
  2. Kustomline54
    Kustomline54
  3. jimmy six
    jimmy six
    Most any epoxy primer and maybe a matching color of the car. Make sure your painter primes the bottom of the door and gets a good coat of body color. After the paint work is done make sure the drain holes are not covered by the weather stripping.
    I’m 5 miles from the beach and Upland is a lot dryer than the humidity for me. Good luck.
    Kustomline54 likes this.
  4. evintho
    evintho
    Epoxy prime and make sure the 4 drain holes at the bottom of the door are clear. Should be good to go.
    Oops, jimmy six beat me to it!
    jimmy six and Kustomline54 like this.
  5. bobss396
    bobss396
    Drain holes must be open for sure. I had my doors apart, zero rust but I gave the inside bottoms of both doors and the area behind the rear seat panels a coat of POR15.
    orangedog and Kustomline54 like this.
