What is everyone doing for door seals on their Model A's? Softseal has some universals but can't seem to find much. Most likely have to adapt one of the universals but curious if others have had luck with a particular piece.
For my Model A, I ended up using some of those universal seals from Soft seal. They needed a bit of tweaking to fit properly, but it worked out in the end. I also heard about Mantaline and their customized elastomeric applications. They helped me out with some tricky seal issues on another project, making custom seals that fit perfectly. If you’re having trouble with the universals, it might be worth reaching out to them. It made a noticeable difference for me and could save you some h***le.
