door windows on 1929 Dodge coupe
Discussion in 'The Hokey Ass Message Board' started by Inland empire hot rods, Jan 20, 2013.
  1. Inland empire hot rods
    from so cal
    Hey guys, looking for ideas on fabricating door tracks/guides, window frames for my 29 Dodge coupe. My doors were pretty bad, the only guide in them was at the forward edge, so there is no guides at bottom or rear, as well as there are no window frames or regulators. I picked up some 32 Ford regulators as I would like to not go electric. I may be over complicating this, but just thought Id throw this out there and see what others have done.
    oh, also where does one find the universal felt channels or guide liners or whatever you call them
  2. I have a set of 29 dodge frames somehwere but you don't them. they were used before safety gl*** to keep things together in case of breakage.
    any regulators that are short enough and made for flat gl*** will work just fine. I have several hundred NOS and used early ford regulators. they would not be my first choice for this conversion.
  3. notaford1
    notaford1
    from webster ny
    I don't know which series 29 you have but a DA doesn't have window frames in the doors they are part of the door itself. The door has a slot across the inside top of the door to slide the window down and then has a cover to close it off
  4. Inland empire hot rods
    from so cal
    I don't know which one I have either, it was beyond a
    Basketcase when I got it. Mine does have the slot at top, and it has one guide that is still part of door, that was all that was there
  5. RMR&C
    RMR&C
    from NW Montana
    Post some pics if you can.
    You can buy new metal channel guide pieces for inside the door, look in any model A catalog. May have to trim to fit.
  6. You can get good quality generic window channel from JC Whittney as well as kat whiskers.
    As far as fabbing something I think I would just go to a wrecking yard or the neighbors yard if you live next to someone low rent and rob the window guides from a whatever car then adapt them to your coupe.
  7. the guide channels inside the doors I make my own 5/8 wide 3/8 tall and have seen guys that just split square tube if you don't have access to a brake
  8. Inland empire hot rods
    from so cal
    thanks guys, I started splitting square tube, just need to get the felt guide liners, will try and post up pics later today
  9. Choff
    Choff
    Mark,
    If you need some pics of the door slides and other **** for these great Dodge doors let me knowl, my P***anger door was in good shape and I have the guts for this door.
    I will be working on my doors again soon.
    Choff
  10. Inland empire hot rods
    from so cal
    Hey Choff! Id love pics, any you have
    Thanks, Mark
  11. Inland empire hot rods
    from so cal
    thanks for your input, what would be your first choice, electric not being an option
  12. Choff
    Choff
    Mark,
    I took a pic of the Drivers door I have been working on, the channel is hard to see on the inside of the door, hope this helps for window installation, I will be doing mine soon, I was going the hand crank route for my windows, Maybe go to your local gl*** shop for side track channels.
    Chris
  13. Inland empire hot rods
    from so cal
    Thanks Chris, what latches are you using? I bought the bear jaw ones, which work great but the window track will be tough around the latch and then coming up with outer handle linkage to the latch is a bit of a ***** also, ideas?
  14. bbrroowwnn
    bbrroowwnn
    from Drums PA
    I also have to do mine yet on my 29 DA but I think i am going the electric route
  15. Choff
    Choff
    Mark,
    Check out the smaller size bear claw latches, I would think the smaller size will work out, I do have the orginal door latches and window mech. from the door insides. I have not gotted to far on that part of my doors, I also thinking like bbrrppwwnn of using Electric windows.
  16. Inland empire hot rods
    from so cal
    thanks Chris, I think I have the small ones, I would like electric windows but think it would be cool and old school to have mechanical windows, let me know what you do with yours
  17. Inland empire hot rods
    from so cal
    Hey bbrroowwnn, what latches does your car have?
  18. Choff
    Choff
    Mark,
    Will do, I need to get busy on the drivers door and get latches soon.
    29 Dodges Rule and we need to stick together on the builds
    Thanks for any input.
    Enclosed pic of the Hemi I have been thrashing on, getting it clean and painted and then fire it up, lots to go.
    Choff
  19. Inland empire hot rods
    from so cal
    Chris, your right brother! I love your Hemi! mine is still being put together in Mississippi, Im hoping to get it in march at the March Meet. What trans are you running?
  20. Choff
    Choff
    Mark,
    For right now it has the orginal Powerflite behind it, going in the car this way if the trany is ok, and then some day go with a 727 Mopar, The engine is and orginal 1954 331 with factory 4 barrel carb and orginal air cleaner, It turns over and so far its been cleaning and rebuilding carb, water pump, fuel pump and etc. Hope to fire it soon.
    Got to love the Mopar all the way with all the 29 dodge builds !!!
    Choff
  21. Inland empire hot rods
    from so cal
    very cool! I swayed a tad and went th400, well thats where Im leaning, but who knows where Ill end up. My engine that Ive been waiting too long for will be a 417 inch 392. Gonna run a Hilborn injector on the 671, should make a lil noise ;)
  22. bbrroowwnn
    bbrroowwnn
    from Drums PA
    Sorry, but I haven't been on this thread in awhile.....I have bear claw latches but mine are on the front of the door as I suicided the doors and there are no outside handles or hinges exposed on the outside.....Going with remote door opener poppers...I will take some pics of where I am at with the doors
  23. dodgekew
    dodgekew
    I only just picked up my door gl*** channel and window regulators this year off ebay USA !
    All the other bits have come from parts suppliers using what ever they had to get the job done.................sorry.
  24. bbrroowwnn
    bbrroowwnn
    from Drums PA
  25. Inland empire hot rods
    from so cal
    cool thanks bbrroowwnn!
