Dot 3,4,5??
Discussion in 'The Hokey Ass Message Board' started by Dan, Sep 15, 2008.
  1. Dan
    Dan
    Are there any "guidelines" as to what to use? Such as vehicles 19**-** use DOT 3, vehicles 19**-2000 use 4,5 or what ever??
  2. bryan6902
    bryan6902
    They all mix except for silicone fluid which I believe is DOT5.
  3. gnichols
    gnichols
    from Tampa, FL
    For street cars use 3. The other stuff is for racing and is more prone to absorb water and the mfgs "expect" racers to change it more often. Gary
  4. TagMan
    TagMan
    Actually, DOT 3 & 4 will both absorb water vapor.
    DOT 5 is Silicone and will NOT absorb water. Don't mix the two types. If you want to go to DOT 5 in an old system, change every rubber component in the wheel cylinders, M/C, change hoses, etc. Also clean out all the brake lines or replace them.
  5. chromedRAT
    chromedRAT
    exactly what i'm gonna do to the plymouth...
