DOT 3 ,4, or 5 brake fluid indentification.
Discussion in 'The Hokey Ass Message Board' started by 2many projects, Aug 27, 2012.
  1. How do I identify the brake fluid in my latest rod that I did not build.
    It appears to be a clear slightly yellow in color with no real overwhelming smell in it's under the floor master cylinder.
    I have a bottle of DOT 5 on the shelf but it's purple in color.
    I know you cant mix them so should I go for the DOT 3 and hope it works?
  2. TagMan
    TagMan
    Good question. I'm not sure if the two would mix together or not, but I guess I'd take a couple of ounces of both fluids, pour 'em in a can and see if they mix together, for starters.
  3. F&J
    F&J
    take some fluid out of the reservoir and put it on a spraycan enamel painted test panel, to see if it bubbles like paint stripper. If it does not affect the paint, it is 5.
  4. snelson57
    snelson57
    Do not mix DOT 5 with either DOT 3 or DOT 4.
    DOT 3 & 4 are glycol based and can be mixed. If you fluid is yellow in color, you have one of these in your car. DOT 4 has a higher boiling pt than DOT 3.
    DOT 5 is silicone based, purple in color and is silicone based. Dont mix it with anything. For many years Harley used DOT 5 in production, but I believe that they are mostly DOT 4 now.
    There is also a DOT 5.1 which I believe is glycol based, but I have never worked with it.
  5. liljonny
    liljonny
    from menifee,ca
    Are you trying to get your fill level up? IMO, instead of guessing just drain/refill to your standards. It'll save you a lot of headaches.
  6. Sixcarb
    Sixcarb
    from North NJ
    You can mix 5.1 with 3 and 4 , I just did a full brake job and for the first time used 5.1 and so far have the best feeling pedal I had in a long time. Not sure if it's the fluid that helped so much but I'm happy witrh it. If you think you may have 5 in there you would need to completely flush before going to another type of fluid.
  7. dot 3 and dot 4 are compatible dot 5 isn't. dot 5 is mainly only used in newer cars cos the other types can destroy the newer style seals. if it were my car i would be draining out the fluid you have in there and filling it with new clean dot 4 fluid (being sure to bleed it all the way through to the wheels) that way you know whats in there and you know you have good brake fluid.
  8. onlyonthurs62
    onlyonthurs62
    ^^^what they said...5 does NOT mix with the other two. If you do you will contaminate your entire system!!!
