Hot Rods Double Flaring Brake Lines
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Jul 6, 2017.
  1. Fortunateson
    Fortunateson
    I have I was told is a double flaring kit. Now I wonder if it is a flaring and swaging kit. Does anyone have a pic of the bubble flaring adapters, not the new style, that I would need in order to then do the double flare? Can these be bought separately from a kit? Thanks.
  2. saltflats
    saltflats
    from Missouri
  3. HOTRODPRIMER
    HOTRODPRIMER
    This is what I have used for more than 40 years,S&K kit. HRP
    jeffd1988 and Fortunateson like this.
  4. Andy
    Andy
    I had a Jag with some odd flares. I just used the double flare thumb tack and only went part way. It worked fine.
    I have a set like the above.
  5. Fortunateson
    Fortunateson
    OK that is what I have. So you use the ****on that has the same OD as the line you are flaring and squish it down and then make th double flare? Maybe time for some learning!
  6. Andy
    Andy
    Are you trying to do a double flare or the British bubble flare?
  7. saltflats
    saltflats
    from Missouri
  8. tubman
    tubman
    I saw a video on "You Tube" about making bubble flares with a regular double flaring tool (like "Andy" said). It looked reasonable to me and IIRC, it had some useful information about positioning the tubing etc. It shouldn't be that hard to find.
  9. Blues4U
    Blues4U
    from So Cal
    The video above shows how it's done, but if you're flaring steel, pr stainless steel, I'd suggest putting a little lubricant on the tip of the flaring tool, it will make the process much easier and save wear on the tool.
  10. Fortunateson
    Fortunateson
    I just want to double flare some lines for an OT late '60's Ford. I'll be using Cunifer (copper, nickel, iron alloy). I'll check out th eposted video. Thanks.
  11. Fortunateson
    Fortunateson
    I tried twice; the first time with the adapter that just fit in the tubing and the second with an adapter that was a little lose. The second attempt was better. Should there be a littlest wiggle room when making the bubble flare?
  12. saltflats
    saltflats
    from Missouri
    Make sure the end of the tubing is nice and square.
    Does your mandrel piece have the tube size stamped on it.
  13. Fortunateson
    Fortunateson
    Yes it does. I have just played with this but I just wanted to make sure I have the correct bits to make the first step bubble flare. I bought a really cool flaring tool like the Eastwood professional tubing flaring kit ($199.99 US/ $239.99 CDN) I got from Princess Auto for $30.00 crazy clearance sale. It does not have the bubble flaring dies just swaging dies on the turret so I will use my little ****on adapters with the kit to make the ini***rial step. A little inconvenience rather than paying another $100 is fine with me!
  14. 99% of the time I can get a good metric bubble flair with a standard inverted flair kit. Use the proper size die and don't squish it all the way. Compare what you get to a pre fab iso bubble. It's pretty close and doesn't leak
  15. choptop40
    choptop40
    done correctly is a beautiful sight to see....
    saltflats likes this.
  16. mediumriser
    mediumriser
    from Ohio
    Spend the money and buy a EASTWOOD flare tool. 100 times faster and perfect flares every time. Should have bought one years ago. BEST INVESTMENT by far.
  17. Mr48chev
    I used a Snap-On flare tool for years without an issue until it got pretty well worn. Same design as what the guys showed above.
    On the Eastwood style tool you have both dies should be on the turret for each size the tool is set up for. At that is how my Eastwood tool works and it works well.
    http://www.eastwood.com/professional-brake-tubing-flaring-tool.html
    Having the tubing cut perfectly straight is a must, deburring the tube is also a must as the burrs will show up in the flare.
    mgtstumpy likes this.
  18. Fortunateson
    Fortunateson
    Well that is what I have except the turret has swaging dies and not the bubble flare dies. So I will use those little double flaring ****ons from the same kit as Hotrodprimer showed which I already have. For $30.00 I couldn't go wrong!
  19. The37Kid
    The37Kid
    Totally agree! I get to use the one in the shop, one more line and my daily driver is back on the road. Bob
    mediumriser likes this.
  20. coast40
    coast40
    AFAIK, you don't use bubble flaring dies to double flare tubing. I have the standard kit like in posts 2 and 3.
  21. jeffd1988
    jeffd1988
    With that cunifer /nicopp it doesn't need alot of torque. Just get it in the flaring tool and just squar up the line put the dye in the line until it stops square onto the flare tool no more pressure then if your going to go to double flare just snug up onto it but not all the way. But of co**** get it to double flare just don't wale on it. When it connects onto the fitting it will make a seal. Then bam no leaks.
    Sent from my Z981 using The H.A.M.B. mobile app
