Hot Rods Double Head Gaskets for a Ford flathead
Discussion in 'The Hokey Ass Message Board' started by socal34, Aug 17, 2017.
  1. socal34
    socal34
    Is there a downside to use 2 head gaskets on a Ford flathead V8 to lower the lower the compression ratio? I need to give my piston a little more clearence
    Thank You
  2. Slopok
    Slopok
    Relieving the heads would probably be a better solution.
  3. ROADSTER1927
    ROADSTER1927
    Valves are usually more trouble. Are your heads milled to much? Gary
  4. socal34
    socal34
    Yes, This is an old engine build, 3/8 x 3/8 . Need to use copper gaskets because they thicker ( if use one) or pistons will hit the head.
  5. Once we had to drastically lower the compression ratio of a high compression engine in order to run a turbo.
    We used a soft copper head "gasket".
    It leaked, and race day was two days away.
    In desperation we used a standard head gasket above and below the copper.
    Drastic reduction in comp ratio, but it held up and we took the fast cl*** trophy with a car we didn't think was ready.
    Gasket held up running over 24 lbs boost. it topped out our gauge.
    why be ordinary?
    kidcampbell71 likes this.
  6. 62pan
    62pan
    I used two gaskets on my Model A with a high compression head. I coated both with a few coats of Copper coat and they are still holding up. Have 2K miles so far.
  7. micky69
    micky69
    from Ohio
    We make gaskets for Flatheads from .027 to .140 at Cometic Gasket.
    flatheadpete and kidcampbell71 like this.
  8. dirty old man
    dirty old man
    ^^^^^^^^^^^ There's your best solution. They're pricey but on a flat deck with a head not warped, you ain't gonna blow them with any compression you can get outta a flathead, ***uming proper torquing.
  9. Bruce Lancaster
    Bruce Lancaster
    And on the thickness choice...try to find a thickness that will put your piston clearance around .040 or so. More kills the turbulence from quench area, actually promoting ping even though compression is lower, and makes engine less responsive. Like a 1978 Chevy with fully dished pistons...bad power and response, plenty of clatter.
