Technical double hole tie rod
Discussion in 'Traditional Hot Rods' started by rustyrods, Apr 4, 2022.
  1. rustyrods
    rustyrods
    from Dixon,Il.
    anyone ever use a double hole tie rod from a jeep for cross steering? I see speedway sells one for $49.00 but a jeep takes a 11/16 th left hand thread , looks the same for $25.00. Need to save bucks these days.
    bob b. likes this.
  2. sdluck
    sdluck
    It worked fine on my model A,I believe it was from a jeep,but I bought it from speedway,The rubber boot rotten away in a short time before i ever put it on the car,I would buy it from pete and jakes .
    RICH B likes this.
  3. Mr48chev
    I've looked at them for years but never used one, My brother's C-J that I was always doing repair work on had one back in the late 70's.
    Crown automotive makes the one you usually find in from the Jeep trinket vendors Amazon shows it https://www.amazon.com/Crown-Automotive-J0640178-Tie-Rod/dp/B00BA76OH0
    This Ebay add has the specs and it does have 11/16 left hand threads. https://www.ebay.com/itm/1749173164...I%3D|ampid:PL_CLK|clp:2563228&epid=1717769696
    The other thing on it is I am pretty well positive that the drag link rod end goes in from the front side as the wide part of the taper is on the front if my memory is correct.
  4. sdluck
    sdluck
    I think it offers a little more turning.
  5. Blairsville G
    Blairsville G
    The one from Speedway has the hole tapered from both sides.
  6. lostone
    lostone
    from kansas
    Anybody have a moog or Napa part number for these ?
  7. krgdowdall
    krgdowdall
    from Alberta
    Try a Moog ES 140 L
  8. sdluck
    sdluck
    Make sure and put a steering dampener on it.
  9. Daniel Dudley
    Daniel Dudley
    If you get one of these, take the boot off and grease it. Then take a little grease and smear it on the inside and outside of the boot before you put it back on. It will soften the rubber and it will have a normal life.
  10. indyjps
    indyjps
    Fordors likes this.
