Technical Downs body windshield
Discussion in 'Traditional Hot Rods' started by HOTRODJON, May 29, 2025.
  1. HOTRODJON
    HOTRODJON
    Long time member but usually just read threads. Looking for a little help. Building a 34 3 window that is in the paint shop. It is a Downs body I bought in the late 90’s, yeah I know, I work slow. The painter asked about the windshield and rear window. I have the gl*** that came with the body but no rubber. It looks like a flat rubber mount windshield like old VW bugs used. Can anybody tell me what I should use or who makes rubber to mount these windows for rubber mounting?
    Any help greatly appreciated.
  2. Bandit Billy
    Bandit Billy
    I don't know about the Downs body specifically, but I would call my local gl*** guru. My guy always has what is required for mounting flat gl***. Just a few weeks ago he mounted new gl*** in a gas pump I restored. He has the correct rubbers just lying around. Drop off that gl*** and frame and let a pro figure it out. That's what I do.
    dirt t, dana barlow and HOTRODJON like this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    As I recollect I used a "T" molding around my coupe, that was from OEM Chevy S-10.
    HOTRODJON likes this.
  4. Can't remember system used for the Downs bodies, but if it looks like flush mount, then urethane(glue), and a T molding(as mentioned above S10) will get it installed.
    Maybe someone with a Downs body, will add some info.
  5. kabinenroller
    kabinenroller
    I purchased the first Downs ‘33 Victoria body after Downs bought the mold from Windsor. It was a mess, the body was channeled over the floor pan, the cowl was down about 3/4” from where it should have been, the rear wheel wells were tapered in at the top, and the windshield opening was far from being symmetrical. I made a template of the opening then had it scanned so I could have a stainless faux windshield frame laser cut. When I got the template back it was obvious how far off the opening was side to side. As for installing the gl***, automotive glazing tape and T molding was all that was needed. I sold the car unfinished years ago, a few years ago it surfaced near Atlanta finished and for sale. I have no idea where it is today.
    HOTRODJON and 51 mercules like this.
  6. HOTRODJON
    HOTRODJON
    Thanks guys, I went to a couple of local windshield shops today and both of them just kinda looked at me like my dog does. I have read about S10 but thought it had to be glued in. I was thinking about just ordering a VW one to try as they are pretty cheap. I also looked at Steele Rubber as a search showed they have some for street rods. I have used their parts and been pretty pleased with their stuff. Will call them tomorrow. I was hoping someone with an early Downs body had been down this trail and knows what will work. Thanks again
  7. HOTRODJON likes this.
  8. krylon32
    krylon32
    from Nebraska
    Yes. It's a glue in with an S10 T molding. Did several back in the 90's when glue ins were the hot thing.
  9. HOTRODJON
    HOTRODJON
    After talking to and reading a lot about this, as posted above, it is definitely a glue in situation. Thanks guys. Now I’m going back and forth reading about butyl tape and urethane to hold it in. Another problem is the gl*** fits the hole pretty tight, I’m not sure there is enough room for the S10 rubber. My painter thinks after the w/s is glued in, just fill the small gap with black silicone. I’m leaning toward the butyl tape for the installation, but wanted some feedback.
    Thanks to all for the help.
  10. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    General information anyone reading this.
    Ironically, If silcone gets past the paint, rot will occur
  11. About 25 years ago, a buddy and I, finished up someone's languishing 33 Ford sedan project, chopped, that needed the windshield. We had gl*** shop urethane in the gl***, cut to fit opening, and the S10 rubber just fits in the gap between body and gl***. It's T-molding. It was a fairly snug fit in that gap, but can't remember details.
