DP 40 question
Discussion in 'The Hokey Ass Message Board' started by Bugman, May 24, 2004.
  1. Bugman
    Bugman
    Will DP 40 epoxy primer work on bare aluminum, as well as on top of the factory finish? Is there anything special I need to do to get it to adhere well? It's my first time spraying it, and it's for another teacher, so I want it to work well, and last awhile. Thanks for the info.
    -Jeff
  2. Unkl Ian
    Unkl Ian
  3. Jdee
    Jdee
    I have used DP-90 on bare aluminum Airplane dashes
    An it worked fine, Get it super clean and scuff with a red scotch brite pad to give it a little tooth then clean again
    before spraying. It should be fine.
    Jdee
