Projects drag car class i.d. numbers question???
Discussion in 'The Hokey Ass Message Board' started by madmak95, Sep 4, 2008.
  1. madmak95
    madmak95
    well i got the car running good enough to make the HAMB DRAGS , but not realy looking good enough. so now its time for paint and body. question i have is the class letters on the side .. the A/B type of letters. so what class would my car be in? it has a 301 chevy and is 112 in wheel base. do i need the weight?
    http://www.jalopyjournal.com/forum/showthread.php?t=289538&highlight=hamb+drags
  2. G V Gordon
    G V Gordon
    from Enid OK
    It would be an altered i am sure. The class would depend on c.i. to weight ratio. Also blown/unblown and fuel/no fuel but that probably isn't an issue right now.
    Enjoyed watching the progress and seeing it run at MOKAN.
    GV
  3. madmak95
    madmak95
    GV i got a good look at your tub at the drags .... one sweet hotrod... i was thinking i would need the weight of the car . there a new truck stop in town , ill have to go see about there scales...
  4. johnrockin
    johnrockin
    from midwest
    Altered model B(32-34?)
  5. Falcon Gasser
    Falcon Gasser
    It would most likely be a B/A, it could also if it is a little heavy it might be a C/A.
    Jon
  6. AnimalAin
    AnimalAin
    Looks to me like the body is shortened and the engine set back more than 25% of the wheelbase; that puts it in a competition coupe class. Maybe B/C. I don't recall there was a class lower than that for these type cars.
  7. madmak95
    madmak95
    the body is what i think is a '36 ford 4 door that was cut down to a 2 door. was like that when i got it. i built the frame and use what parts i had . its chopped a good bit , not sure how much , and channeled about 8 inchs. it would be an altered but as far as the 25% set back , i dont know but it would be a good guess that its that far if not more. i didnt really build the car to a set style , i just built it. so far it runs pretty good and straight... 12.12 @114 mph at the drags.
