Projects DRAG SNAKE "Vintage Terror!"
Discussion in 'The Hokey Ass Message Board' started by Deuced Up!, Oct 13, 2017.
  1. For the simple reason that AC Cars Ltd. had no money to redesign and upgrade. At the time that Shelby approached them, AC was on the verge of going out of the sports car business, one reason being the engine they'd been using was ceasing production. Shelby was looking for something small, light, and cheap, the AC 'Ace' filled the bill.
    When Shelby decided to fit the FE into the Cobra to keep up with Ferrari, a 390 was dropped into a 'Ace' ch***is for a test mule. The car was undrivable. He then brought Ford into the picture, and with Ford doing the heavy engineering work, a new coil-over ch***is was designed and then built by AC. This ch***is was used for all subsequent versions, regardless of engine size.
  2. DDDenny
    I remember the first Cobra ch***is I saw, thinking those main rails looked like the size of coffee cans.
    chryslerfan55 and Deuced Up! like this.
  3. saltflats
    saltflats
    from Missouri
    I remember doing some header patch job on a small block car back in the late 70s.
    Looked like a single big bale trailer frame.
  4. One other thing that many aren't aware of; Cobra production didn't end in '67. While the cars could no longer be imported into the US as they wouldn't meet current safety specs, AC built a 'AC 289' (using the updated ch***is and bodywork) for several years that was sold in Europe and elsewhere. The 'Ford connection' that AC had due to the Cobra program gave them a new lease on life (at least for a while) as they continued to use Ford motors in future designs.
  5. Deuced Up!
    Deuced Up!
    Well I ordered the Tremec Magnum Trans today. Tremec recommended, I talked to the guys at Silver Sport Transmissions and they put together a full kit for me. Extremely knowledgeable folk there, I was impressed! They actually convert the Ford Mechanical Tremecs to Hydraulic etc. They put a complete package together from bell housing to yolk! This will be a crazy simple operation to bolt right to the little 289!
    Yes you read that right, 289. Honestly I was checking on headers for the other direction and pretty much found every new kit car in the country is now running or plans to run the Coyote or LS. In fact the guy from header place said the old ford and chevy small blocks are virtually obsolete! That is all it took for me to jump back on the rails!
    So here is what I am going to do: BOSS 363!!!
    * Bore x stroke: 4.125 in. bore x 3.400 in. stroke
    * Block: Boss 4-bolt main block M-6010-BOSS302
    * Piston to Deck Height: .01 in." below deck (nominal)
    * Crankshaft: **** forged steel
    * Connecting rods: **** forged steel I-beam connecting rods with floating pins and ARP bolts
    * Pistons: Mahle forged aluminum
    I have ordered the short block from Ford Racing and I have sent the specs to Roger Hurst (the guy who blue printed the upper end of the Austins Motor etc.) We will be using AFR aluminum heads and he will decide the combustion chamber size etc. to keep us on at least 93 octane fuel (probably 58cc or 60cc). Jessel Rockers and then as before he will design a custom cam and choose the valves, springs, lifters etc. On the BBC he liked Howard stuff, we shall see what he comes up with. We should be able to pull down 500 hp fairly easily.
  6. saltflats
    saltflats
    from Missouri
    That's good to hear Roger is still at it.
    The last time I talked to him he was not well.
  7. Deuced Up!
    Deuced Up!
    Yep he is still kicking...he is chomping at the bit to get hold of my numbers etc. He has called me twice
    since I mentioned I was going to need his services on it etc....lol
  8. Deuced Up!
    Deuced Up!
    If I did the math correct (give or take a few) a 58cc head on the 363 should be about 10.6 to 1, a 60cc will make about 10.4 to 1 and 72cc 9.1 to 1. So I am thinking 58cc before Roger even gets his hands on it.
  9. Deuced Up!
    Deuced Up!
    Wheels are moving along...I spoke with Scott from ET yesterday and the only hurtle left if figuring out how and where to place the valve stem. No big deal right?!
  10. kidcampbell71
    kidcampbell71
    If laying on concrete isn't a big deal, valve stems on the inside would be an interesting outside look dynamic. Clean. Most wouldn't notice, but others would think you have some sort of top secret tires. And hey, maybe you do. Keep 'em guessing.
  11. alchemy
    alchemy
    I like to build with the KISS method. There's no way I would put valve stems on the inside of the wheel.
  12. Back in the old days when we would simply reverse a stock wheel we always left the stem on the inside. PITA to check pressure and the wheel was always in the wrong position of course.
  13. Deuced Up!
    Deuced Up!
    Merry Christmas Folks. Best wishes to you and your families.
    Sent from my SM-G930V using The H.A.M.B. mobile app
  14. saltflats
    saltflats
    from Missouri
    Same to you and your Randall.
    And we did get a white Christmas up this way after all. :)
  15. loudbang
    MERRY CHRISTMAS to you and yours. No snow here, sunny blue skies, and 85 :rolleyes:
  16. Malcolm
    Malcolm
    from Nebraska
    I love the direction you're headed with this and the Boss 363 is a great offering from Ford Racing. Stout, durable and still in the compact little 289 exterior dimensions!
  17. Well I can tell you right now that whatever happens I am not going to like the color of it. :D :D :D
  18. Deuced Up!
    Deuced Up!
    ****** you really need to look at the Cobra through the bottom of an empty moonshine jar and then you will love it! Lol
    raven and loudbang like this.
  19. saltflats
    saltflats
    from Missouri
    Is that where you found it o_O :D
    Deuced Up! and loudbang like this.
  20. wrenchbender
    wrenchbender
    James you are probly right lol
    Deuced Up! and chryslerfan55 like this.
  21. Deuced Up!
    Deuced Up!
    See all you have to do is mention moonshine and Jackson is back... lol
    chryslerfan55, loudbang and saltflats like this.
  22. wrenchbender
    wrenchbender
    I never left Randall just been patiently waiting on some progress lol
  23. Deuced Up!
    Deuced Up!
    Tell me about it! This thing is 11 pages of all talk and no action so far...Don't worry we are about to get going.
  24. saltflats
    saltflats
    from Missouri
    You know Jackson ain't happy tell he see some drive shaft dance or a 80W90 oil slick. :eek:
    loudbang and Deuced Up! like this.
  25. Deuced Up!
    Deuced Up!
    No photos yet but I got an email Christmas eve saying the Nose is out and the rear section is laid up and cooking in the mold. Just a few house keeping issues left like a couple of doors, inner trunk liner, and the hood liner. Should have everything wrapped up around the 1st/2nd week of the new year!
  26. saltflats
    saltflats
    from Missouri
    Are you itching yet?
    enloe, chryslerfan55 and loudbang like this.
  27. wrenchbender
    wrenchbender
    No James I'm freezing to death it's just too damn cold lol
    enloe, chryslerfan55 and Deuced Up! like this.
  28. saltflats
    saltflats
    from Missouri
    Cold up here also.
    I am glad my shop is in ba*****t.
  29. Tickety Boo
    Tickety Boo
    from Wisconsin
    That ain't Cold =
    Pay back for the time we were at the Meltdown in the 90s and you said it was just right.:rolleyes:
    We got -4 with -20 wind chill, heck just got out the winter coat yesterday:D
    Send up some of that clear stuff.;)
  30. wrenchbender
    wrenchbender
    Norb there is a reason I live in the south but I'm thinkin I might need to go further south lol hell Randall you better have one hell of a heater lined up for this slippery snake lol
    chryslerfan55 and Tickety Boo like this.
