Technical Drag-U-La build...Help Wanted!
Discussion in 'Traditional Customs' started by Jonnylightening, Jan 3, 2021.
  1. TRENDZ
    TRENDZ
    Bell- crank coil overs can be installed anywhere. Look at indy car suspension. You can lay them horizontally if you wish.
    bchctybob and gimpyshotrods like this.
  2. Greg Rogers
    Greg Rogers
    This is SO cool. I loved the Munsters when I was a kid. I remember watching it on the old black and white one evening and the Herman drag racing episode came on. WOW my favorite show with my favorite topic, Then they built a dragster!!! Couldn't get any better!! Sorry no technical help, but I want to encourage you on- a great idea!
    bchctybob and chryslerfan55 like this.
  3. Koz
    Koz
    I'm watching this thread closely! One of my favorite all time theme cars. In Pa. it would be a reach to get plates on.
    mad mikey likes this.
  4. They didn't cool the engine it was a dragster and was built to run 1320 feet at a time.
    chryslerfan55, Deuces and Okie Pete like this.
  5. -Brent-
    -Brent-
    I wonder what airplane that canopy (is that the right term for it?) is from?
  6. grumpy65
    grumpy65
    :eek::eek::eek: That would take the fun out of it all very quickly...................
  7. mohr hp
    mohr hp
    from Georgia
    At the end of the Munster TV series, they made a feature length movie, in color, which features Dragula doing a lot of road racing in Europe. I imagine many Hollywood liberties were taken, but in order to have productive filming days, it had to have had an adequate cooling system. A great must see film for Dragula fans.
  8. Jonnylightening
    Jonnylightening
    ok guys I think I'm going to go elliptical rear suspension. Plans are to stack and weld a 2x2 tube on top of my 2x3 frame just above where the rear would go and notch it out for a 4" C for rear clearance....if that makes sense
  9. lippy
    lippy
    from Ks
  10. Jonnylightening
    Jonnylightening
    Whats weird about it? Please inform me!
  11. Jonnylightening
    Jonnylightening
    Sorry its not drawn to scale!
    Just Gary and bchctybob like this.
  12. davidvillajr
    davidvillajr
    If you didn't channel the body(?:D) quite so deep, you could probably find yourself another couple inches of top-to-bottom leg/body room. I don't think it would make a negative impact and you'd still preserve the look. Just a thought.
    Jonnylightening likes this.
  13. X38
    X38
    That's 1/4 eliptic.;)
  14. bchctybob
    bchctybob
    The sketch looks good, you’re on the right track.
    Quarter elliptics work great, I had them at all four corners of my roadster. In front I deleted the shackles and used the spring as the lower bar of a 4 bar system. I used two stock Model A front springs, the ones everyone threw away when they bought new reversed eye springs. You can add and subtract leafs to get the ride. Speedway or Posies sells height adjustable brackets too I think.
    AHotRod likes this.
  15. mohr hp
    mohr hp
    from Georgia
    If you have a little driveshaft, you need the suspension to stop both up and down travel, not the u-joints!
  16. Jonnylightening
    Jonnylightening
    Ordered 1/4 Elliptics off speedway motors. What should I do as bars? 4 link with panhard, triangulated 4 link,...? What size tubing should I use with what heim joints/clevis?
  17. A Boner
    A Boner
  18. davidvillajr
    davidvillajr
  19. Rusty O'Toole
    Rusty O'Toole
    You need an independent rear suspension. Marty suggested swing axles - a Mercedes low pivot swing axle from the fifties or sixties would be ideal and easy to install. They came with coil springs. The swing axle might not work well with drag slicks or wide tires. Or, there are a million japanese SUVs in junk yards with small, light IRS that would work fine in a light car. This gets around the problem of allowing rear axle to move up and down with no drive shaft. With IRS the differential is fixed to the frame.
    Lay the radiator flat in front of the body, under the area where the Moon tank is on the original. Put perforated steel or mesh over it, with an electric fan blowing upward and it will cool fine.
    Low pivot swing axle. They came in "finmobile" Mercedes sedans of the fifties and sixties. The middle, supplemental or camber compensator spring can be easily removed.
  20. flyin-t
    flyin-t
    Of course they did, pics are from the original build.
    They must of been dealing with covid too.
    4DC9A999-E7E8-4F74-A6AB-8F8F31A74275.jpeg E19099A0-0A59-42B4-BF5E-9C1BF9593117.jpeg
  21. Deuces
    Deuces
    Yep! Them^^^^^2 guys look normal...:):(
    Just Gary likes this.
