Dragster frames........picture thread.
Discussion in 'The Hokey Ass Message Board' started by Royalshifter, Dec 21, 2007.
  1. Little Wing
    Little Wing
    from Northeast
    There is a whole 440 line and there is alot of interchange,,the frame I posted could be a transitional frame as you can see the Eelco/CR frame mounting plates and no ****ter shield
  2. ain't history fun!!!!!!!?????
  3. Little Wing
    Little Wing
    from Northeast
    actually looking it over never seen this cage the 2 lower hoops in the back and the side rails actually come outside of the cage and curve back in,,,hmmmmmmm
    ok what the storying in this lil fella
  4. Little Wing
    Little Wing
    from Northeast
    So its interesting that all these old frames were gas welded,,I wouldnot have thought gas welds to be strong enough
  5. oh ****! I can't believe you went there again.
  6. 1lowtoy
    1lowtoy
    Whats the wall thickness on the bottom rails of the K-88?
  7. 1lowtoy
    1lowtoy
    Can I have some specs to :rolleyes:
  8. Little Wing
    Little Wing
    from Northeast
    big tubes should be .120 -.125
  9. 1lowtoy
    1lowtoy
    Hey little wing, do you got any of the specs on that k-88 of yours? The bottom rail length, wheelbase?? I really wana build my own k88, so bad ***. Thanks for any info you can give man. Im really greatful
  10. Little Wing
    Little Wing
    from Northeast
    This a K-88 or TE-448 ?? Was'nt the K the same just Eelco made it and it had different mounting plates?
  11. Church Key
    Church Key
  12. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Wow, for under $500 you could have a roller ch***is, just add welding and rear tires/wheels. Awesome.
  13. Little Wing
    Little Wing
    from Northeast
    yep they were'nt that bad though that may have been alot back then..
  14. LabRat
    LabRat
    Thought you guys would dig these ......
  15. Little Wing
    Little Wing
    from Northeast
    anyone have close up pix of a side mount lever shock set up ?
  16. Kerry
    Kerry
    Sorry to break away from the Ch***is Research stuff but here are a couple of current pics that Hellraiser took at Nosurf's HAMB-B-Q. Greezy was trying it on for size.
  17. Royalshifter
    Royalshifter
    Moderator
    Dammm that is looking awesome Kerry.
  18. Kerry
    Kerry
    Thanks Skip!
    Here's one more.
  19. HemiRambler
    HemiRambler
    Kerry!
    AWESOME!!
    Keep up the GREAT work!!!
    Worked on mine ALL DAY today - took care of some "naggin' 'lectrical issues" - darned electrons. Loved every minute of it - truth be told.
    I can't wait to see yours smoke the hides!!!!!!
  20. BigW
    BigW
    looking good nice job like see up close.like the pic
    bigw
  21. Little Wing
    Little Wing
    from Northeast
    Anyone know HOW MANY different versions of the TE-440 were made,, I know of 3 ,,the front end change and at least 2 different roll cages
  22. Kerry
    Kerry
    Weren't you going to build a Ch***is Research digger? Show us your progress.
  23. Slim Pickens
    Slim Pickens
    RoyalShifter...AWESOME! & Kerry 100%!
    Thanks, Slim
  24. Little Wing
    Little Wing
    from Northeast
    relax there you,,working on it still cutting pieces and fitting things. soon enough there will be pix
  25. Little Wing
    Little Wing
    from Northeast
    Anyone with a TE-440 frame ??? need to know are the bends pie cut or is the tubing bent ?
  26. lippy
    lippy
    from Ks
    Kerry, the car looks great! Gonna be some fun there!:D
  27. Little Wing
    Little Wing
    from Northeast
  28. KING CHASSIS
    KING CHASSIS
    Kerry ,looks very good. And that trailer is perfect too.
  29. Kerry
    Kerry
    Thanks Brian!
    I hope to get the block filled this weekend.
  30. Yo Baby
    Yo Baby
    A copy of the invoice for Shirley "Cha Cha" Muldowneys' first dragster ch***is.
