Projects Dragster project - King Chassis changed my mind.
Discussion in 'The Hokey Ass Message Board' started by Kerry, Aug 30, 2009.
  1. KING CHASSIS
    KING CHASSIS
    Just found this. I am a bad influence on a few people. ha,ha.
    But I like what Rich and HemiRambler say. Put in what you got and hunt for the other stuff. We gotta see another digger running around here brian
  2. Ron Mayes
    Ron Mayes
    Kerry run the 273-360 can and a cut down...tail shaft... 4 speed with Pro shifted gears, just use 3rd and 4th......i had this in my TE440, its kick *** :D:D:D:D:D
  3. get it done son!!
    T.H.
  4. KING CHASSIS
    KING CHASSIS
    Kerry, I want to ask you. What route are you going with this car. I dont mean trans wise. But you going tire smoker or hook and go?
    The tire smoker deal is harder to learn. I sometimes wish that I did a automatic just to get down the track . Then built a tire smoker to try to figure out. With Rusty's comment, I think that some people dont understand what I'm trying to do.
    I am not trying to be just a smoke show. But do it and run a number. My small block doesnt put out enuff horse power right now to do what I want to do. Soon as I have to pedal the motor, it looses its momentum and boggs out. Things are gonna change this winter if money is right.
    But with your blown/injected Hemi you could probably pull it off dirrect drive.
    Even if you plan on going hook and go route. (which is the only reason you would need a reverser after your burn out)
    Just forget about that and have a couple of people push you back after a burnout.
    Track help is easy to find with a car like that.
    Anyone that wants to know more about the tiresmoker deal. Check out this thread. http://www.jalopyjournal.com/forum/showthread.php?t=372986
  5. Kerry
    Kerry
    That smokers thread has a lot to do with me struggling with this decision. Going with the automatic pretty much means a hook and go setup. I'm not sure there's a good way to do a smokey p*** while gaining traction with the automatic. Like you said, a lot of pedalling.
    Going with the clutch pretty much means smoking it to get off the line and trying to maintain that fine line between bog and slip.
    I don't want to be an exhibition car either. I want to set a baseline and see just how much I can improve on it. So right now I plan on using the complete automatic setup I have and that means hook and go. I don't plan on doing burnouts and I do not have a trans brake, just the pedal. I'm going with a very mild cam so even with the blower, alcohol, and injection, we'll have to see if I have the stuff to pull a direct drive. I could always launch in 2nd or even third. Just have to see what kind of stall my mystery converter has.
    I've never driven a purpose built drag car so the automatic is probably a wise move from an educational standpoint and getting used to the way the car drives.
    When the automatic dies or I get bored with it I can switch to a clutch setup. Even then I'm waffling between a high-low box or direct drive. More cam might be in order at that point.
    I do still aspire to doing the smoker setup... someday.
