Drain gas tank by evaporation?
Discussion in 'The Hokey Ass Message Board' started by T-Time, Jun 26, 2010.
  1. T-Time
    T-Time
    from USA
    **x
  2. big-vin
    big-vin
    get a small hose and syphen (spelling) it out
  3. chopped
    chopped
    A year? If it got in it has to go out. A baffle creating a dam maybe? Turn it, wait , turn it and wait. repeat until you figure out the path.
  4. hotrod1940
    hotrod1940
    Just a thought, using proper safety precautions, drill a hole and install a pet****.
  5. nutajunka
    nutajunka
    Two gallons mixed with a fill-up should do it , if there isn't water in the tank. Another way to get one to air out quicker is to put an air line in it with a small amount of pressure to help it evaporate.
  6. 56don
    56don
    It won't evaporate completely.What you will have left is a thick sticky moll***es like ****. It will get as thick as tar and eventually turn hard as epoxy.If you are going to ever use the tank, you need to drain it out somehow if its old.
  7. pdq67
    pdq67
    Might consider adding a can or two of Seafoam to it's tank to help burn everything up.
    pdq67
  8. indyjps
    indyjps
    The **** thats left isnt evaporating because its not gas, its sludge. I wouldnt want to leave an open tank left to evaproate for safety reason.
  9. HemiRambler
    HemiRambler
    Be sure to take a peek in there and make sure there is no coating of crud about to flake off - that cna happen with OLD gas tanks - ask me how I know...
