'53 Customline Tudor I removed the rear window trim, door panels, and seat to prepare for seat belt install and interior work. I want to seal the floor and inside of the quarter panel below the window while i'm at it. A previous owner welded in new metal to repair rust in the cavity under the window, but did not seal the inside. I can see the bare metal on the back of the patches from inside the car. I also do not see any drain holes. Were there no drain holes from the factory or did they probably just get sealed up in the rust repair? I ***ume I can just drill a small hole at the low spot and carry on with my sealing. Thoughts?
There were drain holes in my '54 if the window seals are shot the holes can plug up with dirt mine were loaded so nothing could drain out so I enlarged the holes a little. This might be a good thing to add like newer cars have to keep the crud and moisure out. https://www.ebay.com/itm/2831855899...81sJpFOWexeX61jKQ_7PsqIRXL5eT7cYaAl1iEALw_wcB
