drain your compressor
Discussion in 'The Hokey Ass Message Board' started by meengrinch, Aug 10, 2010.
  1. 39 All Ford
    39 All Ford
    from Benton AR
    LOL,, damn, you might check that pressure guage also.....
    20 psi sounds like nothing, but take that 20 lbs x a few square inches of surface area and the forces add up. I wonder how many thousands of square inches of surface area on a 60 gallon tank. (about 2,000 sq inches?)
    Say 2,000 x 20 psi, impressive stored energy.
    Say 2,000 x 150 psi, Scary stored energy.
    the surface area of a valve would not be huge, but a valve in a big bushing, more surface = even more force.
    High pressure can be freaky.....
  2. August 10, 2011... National Drain Your Compressor Day!!
  3. raidmagic
    raidmagic
    So I forget to do this all the time. Should it be drained untill all the air is out or just untill water quits coming out?
  4. DBruce
    DBruce
    After I drain it I wait a couple o few minutes, tip it forward & out of the drain tube another pint or so come out.
  5. Mr48chev
    That was called quitting time at 5:05 if not sooner at Frank Weaver Pontiac in Waco, Tx in the early 70's. When you heard the compresser being shut off and drained it was time to clock out and head home. I never had a problem with my air tools when I worked there either. In fact I still have and use the same Chicago Pneumatics 727 impact that I had then and it has never been worked on.
    Draining the tank on a regular basis not only saves the tank but it damned well saves air tools and related equipment.
  6. MP&C
    MP&C
    I knew I'd forget to drain mine, so when I installed the air compressor, I removed the copper tubing going from the compressor head to the tank, and ran it through a Pneumatech dryer, so the air is cooled and dried before it even hits the tank....
    The pressure switch had two spare contacts, so the dryer is wired there so it comes on with the compressor.
    The tank on the compressor already came with an automatic drain installed, and just in case, one was also installed at the far end of the air line.
  7. Retro Jim
    Retro Jim
    I do once a month but I am the only one using it . Been working for me so I will stick with my method . I also drain the water separator regularly . Compressors ain't cheap and always seem to break down when needed the most !
    Retro Jim
  8. markjenks
    markjenks
    When I put in my 60gal in the garage, I made sure it was easy to drain the tank. Was all the way under it and hard to get to.
    Put a 90deg 1/4" pipe fitting on it, 12inches of straight 1/4" and a ball valve.
    Right there in front of the compressor, and easy to operate.
    The easier you make it, the more often it gets done.
  9. 39 All Ford
    39 All Ford
    from Benton AR
    I have always heard that the air should be completely exhausted.
    I stated earlier that my compressor has an automatic drain which helps a lot, but my shop has an extensive air line system that I drain every couple or few days. When I exhaust these air lines, lots of vapor continues to come out until virtually all of the air has escaped.
    IMO to do it right all of the air has to go at least every few days.
  10. DBruce
    DBruce
    a pic of my drain extension, I usually this chore w/my foot
  11. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I keep mine on a slow bleed, and drain it down once a month or so. Always switched off overnight.
