Drilled backing plates and rain
Discussion in 'The Hokey Ass Message Board' started by chota5, Aug 8, 2010.
  1. chota5
    chota5
    from Nor Cal
    Is it scary, or just slightly less stopping power. I'm talking about drilled front backing plates for drums. Any experiences?
  2. drill them , you will be just fine.
  3. chrisntx
    chrisntx
    from Texas .
    Just fine....the angry red wasps love those holes to build nests inside
  4. Kirk Hanning
    Kirk Hanning
    x2 I've driven in a torrential thunderstorm/downpour and didn't know the difference.
  5. AnimalAin
    AnimalAin
    Probably lets the water out better than the original setup; I wouldn't anticipate any more problems than usual.
  6. 29AVEE8
    29AVEE8
    And lets air in to dry them. Just "drag" them a couple of times before you need them.
  7. skidsteer
    skidsteer
    They aren't waterproof before you the drill the holes, thus 'brake fade' was common with stock drum brakes after driving through a big puddle.
  8. Dirty2
    Dirty2
    No problem for me .
  9. Deuces
    Deuces
    Sounds like a problem waitng to happen!! Just drive carefully in the rain if you decide to drill those out..
  10. tommy
    tommy
    We were taught to apply the brakes lightly after fording a stream or a huge puddle. The shoes need to be under water for a problem to occur but is easily rectified by applying the brakes to dry out the linings. It doesn't take a lot.
    You won't get enough water splashing into the holes to cause a problem.
  11. Just Gary
    Just Gary
    Besides rain water, has dirt or gravel ever gotten through anyone's drilled backing plates and affected braking???
    Thanks.
  12. 26 roadster
    26 roadster
    never had any problems other than brake fade, even with air scoops.
