drilling an 8 ball for shifter knob
Discussion in 'The Hokey Ass Message Board' started by skinnydennis, May 23, 2013.
  1. ParkinsonSpeed
    ParkinsonSpeed
    I got one of the ******* 8 balls and put it on my transfer case lever, i used a oil filter wrench for a import and some shop towels. That worked just fine at a low speed and 3 bit changes to the desired I.D. then tapped. They guy that bought it still has it on there to this day.
  2. chubbie
    chubbie
    2 pieces of ply s****, 1 1/2 hole saw. hold the ball with the ply s****s and put it in the vice. I used my HAMBer drill (small) It's still lay'n around here somewhere.
  3. i just wrapped one in a rag and clamped it in a vice, then used a wood paddle bit to get a flat spot for the jam nut to seat on. then used the the pilot hole from that bit to start the regular bit. i then drilled and tapped a 1/4 pipe ****** (close) to 3/8 16 and glued it in.
  4. bobadame
    bobadame
    Hold it in a 3 jaw chuck in a lathe. Drill and tap it with ordinary high speed tools.
  5. R Frederick
    R Frederick
    from illinois
    Heck, we got three more pages to go before you can call that, lol.
    Heat the shifter with a torch, then shove the ball on it, most of it should stay on there.
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    You have to take a shower with dryer sheets to get there :D
  7. fab32
    fab32
    Just did one for the '38 last week. Wrapped it in a shop towl, clamped it in my drill vice and drilled away. Tapped it for 5/16 fine thread and spun it on the shift lever. If it were any simpler they would have women doing it.:rolleyes::D
    Frank
  8. verno30
    verno30
    I chucked mine up in the lathe and used a center drill. They're like an M&M. Hard candy shell but soft in the middle.
  9. Drive'em
    Drive'em
    I've drilled 2, #13 pool balls, one for me another for a friend. Just put it in my drill press, wrapped in a towel, drilled and tapped for the shift lever threads and added a locking nut under it and that's it, really cool shift knob that matches my paint scheme.
  10. 52lomofo
    52lomofo
    go to wal mart they have an 8 ball wheel spinner 14 dollars less h***le should fit or could make fit shifter
  11. Muttley
    Muttley
    Every time I think the HAMB might be starting to slip a bit a post like this one restores my faith.
  12. tommyd
    tommyd
    from South Indy
    :):D:p!
