Drilling Cranshaft Oil Passages
Discussion in 'The Hokey Ass Message Board' started by Big John M, Jul 18, 2009.
  1. Big John M
    Big John M
    from New York
    Does anybody specialize in drilling oil passages in 4 banger crankshafts for pressurized connecting rod oiling or any other model crankshaft that will swap in ? Would like to do full pressurized oiling in my Model A 4 banger.
    Thanks John
  2. gas pumper
    gas pumper
    Iv'e done this on Techumsa (sp). one cylinder engines that I used to race. the theory is the same.
    I held the crank in the milling machine vise and using a long drill bit started at the rod journal and aimed for the main. Used a center drill to get started on the angle. then a short drill, then a long drill. I put a groove around the main journal so oil would hopefully be constant flow to the rod.
    If there is not a clear path to do it in one shot then you need to do intersecting holes and plug the leakers.
  3. BCCHOPIT
    BCCHOPIT
    pm JETMET he lives in NY. I dont think any guys like drilling cranks but they get it done.
  4. jetmek
    jetmek
    thanks bill...its a bit dicey but should be able to do it....
  5. treb11
    treb11
    there was a multi part article in $treet Rodder about these engines built by a shop that did all the tricks, counterweighting, etc, etc
  6. fordcragar
    fordcragar
    from Yakima WA.
