Drilling exhaust manifold
Discussion in 'The Hokey Ass Message Board' started by Chickenfriedsteak, Jul 29, 2012.
  1. Chickenfriedsteak
    Chickenfriedsteak
    This may be a dumb question. Here goes: I have a Chevy 235, pretty basic. One of my exhaust manifold studs that connects to the collar where the donut gasket connects is broken off. My question is this: instead of removing the stud and replacing it, would it hurt to drill all of the way through the exhaust manifold, and use grade 8 bolts and washers to connect the exhaust pipe? Why would this be a bad idea?
  2. gimpyshotrods
    gimpyshotrods
    Been there, done that, worked fine.
  3. burnin53
    burnin53
    from cuba,n.y.
    There is no reason not to drill it. Makes it easier to deal with. Then if it breaks in the future,just put a new bolt in it.I do it all the time.
  4. trbomax
    trbomax
    Ive done it w/v-8 manifolds. I'd use ss or br*** bolts and nuts though.
  5. olds vroom
    olds vroom
    I drilled mine out retapped them and made new studs out of stainless rod and used br*** nuts , when I had to change the gasket years later they came off like I put them on yesterday.
  6. RagtopBuick66
    RagtopBuick66
    Pretty common fix. Hell, I even did it to the top row of bolts that connect the exhaust manis to the cylinder heads on my FE 390 for the same reason.
  7. fastcar1953
    fastcar1953
    worked for me a couple of times on ot car.
