Drilling Heavy '32 Axle
Discussion in 'The Hokey Ass Message Board' started by firemanjer, Feb 12, 2009.
  1. firemanjer
    firemanjer
    from Colorado
    I had searched here and found a lot of good ideas and ways to drill an I-beam axle but I didn't see a step by step with pics. This is my first tech post so here goes. All the ideas and tricks I used were stolen from fellow HAMBers and one of my local shops. I've heard many people say, "it's easy, not rocket science" which I didn't believe at first.
    Started with a new Ch***is Engineering heavy 32 axle. I like the biggest holes you can fit in an axle. The inside of the i-beam on this axle is 1 3/4". I decided to use an 1 1/4" bit. Measured the center. I wanted about 1" between holes, that makes the holes 2 1/4 apart on center. I used a contour gauge to make a pattern for the center of the axle (pic 1). I transferred this to cardboard (pic 2). With the center marked on the cardboard I was able to quickly mark the vertical bit of each hole. I measured and measured and had my friend re-measure and check everything before we started (pic 3). I also cut a 1 1/4 circle out of cardboard and traced it on the axle to see how things would look (pic 4).
    With 1 1/4 hole saws and cutting oil in hand, my friend Kevin and I use his new drill press to first drill pilot holes with a 1/8" bit. Started by center-punching each hole (pic 5).
    Then the hole saw. The drill press was set on its lowest setting, 200rpm. Using very little pressure and letting the bit do the work produced a pretty good hole. I was worried about blowing through on the other side but it looked good also.
    All the hole took about 3 hours to do. I've never done this but I think it turned out pretty good. I then cleaned up the holes with a drum sander on a die grinder using varying grits (pic 9). After it was almost cleaned up I switched to a flap wheel. For a first timer, not to bad I do say so myself.
    Thanks to kapuron for the drill press and the beer. Thanks to A1 Street Rods in Colorado Springs for tips and encouragement
  2. rick finch
    rick finch
    Wow, patience wins out! Good job.
  3. Little Wing
    Little Wing
    from Northeast
    Did these with old Drill press drilled lil pilot holes first ,then used the whole saw ,,and yeah slow and steady,,used a sharpie and tape measure bout 45 or so. Yours looks good nice work
  4. 067chevy
    067chevy
    I done my ch***is engineering axle with 1 inch drill bit at 3 inch centers. Use plenty of cutting oil and slow or you won't drill very many holes.
  5. Eldorado Rodder
    Eldorado Rodder
    Nice Job on the Lighting Holes!
    So how many hole-saw's did you eat in 3 hours?
  6. Chamfering the holes is nice.
  7. lowsquire
    lowsquire
    from Austin, TX
    I did mine with a broach bit in a holder to put it in a drill press. those things cut so nice.
    Makes me want to buy one of those slugger magnetic base broach drills. they are damn dear though. saves money on holesaws i guess!
  8. firemanjer
    firemanjer
    from Colorado
    I didn't have to change hole saws but did just to be sure it would cut nice. Just used 2. 3 hours=4 beers, taking pictures, shootin the ****. Probably went slower than I had to but never done it before
  9. Little Wing
    Little Wing
    from Northeast
    its fun to do ,and really kinda easy ..I was intimidated at first the I went on a hole drilling frenzy :D
  10. MedicCustoms
    MedicCustoms
    looks cool should look nice in your ride thanks for thanking the time to take pics and post them
  11. Ratty55
    Ratty55
    from Frohna,MO
    Here's mine. Stock A axle. 1 inch holes on 2 inch spacing. I did it on a Bridgeport style mill at school. 1 inch = 200 RPMs
    Justin
  12. Jimmy2bottle
    Jimmy2bottle
    kinda makes me wanna do some drillin!... maybe I missed it but how much drop did that axel have?
  13. firemanjer
    firemanjer
    from Colorado
    Jimmy, It's a 4 inch drop. The only one Ch***is Engineering sells
  14. bobss396
    bobss396
    Now the trick is, how do you get the lightning to go through them?
    Bob
  15. firemanjer
    firemanjer
    from Colorado
    Thats an entirely different thread by it's self.
  16. Eyeball
    Eyeball
    I did this Model A axle for a new project a few weeks ago, I just can't build up the nerve to drill my heavy 32.
  17. noboD
    noboD
    Ka Chow!!
  18. TimDavis
    TimDavis
    haha....I'm still chicken to drop any of my Heavys....***le of the thread should be "Drilling an easily replaceable CE axle"
  19. spooler41
    spooler41
    Some one is dragging their feet if it took 3 hours to drill an axle. I did my 40 axle in about 30 min. My hole saw is still working fine after drilling it, I just made a quick drill jig ,did the lay out, and punched a bunch of holes. If I could get the $100.00 that Socal gets for this operation I'd do it all day long.
    ..........Jack
  20. brentthebarber
    brentthebarber
    that's a clean looking axle, kinda funny you posted this I have drilling to do this weekend too, wishbones and axle, good job.
  21. Kapuron
    Kapuron
    from Colorado
    Dragging their feet? We get it........you are soooooo much faster at drilling an axle. I thought this is the site where you share your hot rod experience with other guys that share the same type of experiences. Usually a post like this warrants constructive criticism. I don't think the post was ***led, "Drilling a heavy '32 axle fast". The time it took to drill the axle is irrelevant. If certain individuals want to take an opportunity to show how much cooler they are then start your own post. Don't use another guys post to dog him. I would encourage more guys to take your time, have a couple of beers, and just enjoy.
  22. Little Wing
    Little Wing
    from Northeast
    did you see any problems ?? can't you see everyone took everything with a laugh ,,why start stirring the ****e and ruin a good thread,...gezzzzzzzzz...,and please not to many beers as you are operating equipment
  23. miraclepieco
    miraclepieco
    I just need to drill two holes in my I-beam for shock mounts; any chance of doing it on the car without removing the axle?
    RH
  24. Don's Hot Rods
    Don's Hot Rods
    from florida
    Sure. A drill press just makes it so much easier, but people drill holes in axles, frames, etc all the time on the car. Just use a good drill motor and bit, wear some eye protection, and have at it. In the next few days I have to holesaw 4 holes 2.25 inches in diameter into my new frame for some crossmembers, wish I could have done it on the drill press, but the frame is already together. Slow drill speed and lots of cutting oil will get it done though.
    Sometimes the best bet is to drill a small pilot hole first then work up to the final size you need.
    Don
  25. Deuces
    Deuces
    They probably use a indexable drill with carbide inserts to drill those.... With plenty of coolant!!
