Hot Rods Drilling holes in Blower Pulleys
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Dec 12, 2022.
  1. Bonehead II
    Bonehead II
    Have any of you guys done this before, ? the wife said that she won't ride with me because it makes to much whine. as I look at her and think to myself yea right. Its 8mm belt & pulleys, If you have how many holes and what size.....Thanks
  2. twenty8
    twenty8
    ..... and then drink the wine.
  3. mad mikey
    mad mikey
    Dump her, lose her. you don't need this!:D
  4. mgtstumpy
    mgtstumpy
    I presume there are no holes for a reason, I'd gather that loss of inherent strength being a solid flange as the holes reduce the surface area of parent material. Also the forces required to turn both pulleys. That whine is the nature of the beast.
    mad mikey, twenty8 and Budget36 like this.
  5. Budget36
    Budget36
    Tell her if she stops, maybe it will too;)
  6. DDDenny
  7. Bandit Billy
    Bandit Billy
    If my blower made wine my wife would ride with me more often
  8. Bob Lowry
    Bob Lowry
    Have some fun with her....add a gear drive and she what she says...
    Tman likes this.
  9. Kevin Ardinger
    Kevin Ardinger
    Endless entertainment!
    chevyfordman and squirrel like this.
  10. AccurateMike
    AccurateMike
  11. ccain
    ccain
    How tight are you running the belt? Too much tension on that belt will make it whine louder.
    With my luck, I'd drill it and end up getting it unbalanced somehow and cook input shaft bearings.
    As for the other thing... my truck is where I go when I want to make all that whining to go away. :D:D:D
  12. J. A. Miller
    J. A. Miller
    from Central NY
    And a quick change for good measure.
    Bob Lowry, Tman and seb fontana like this.
  13. lostone
    lostone
    from kansas
    I've seen quite a few back in the day that were drilled. Never hears of a failure due to holes.
    Don't remember the size or number drilled just that the guys that did it said it greatly reduced noise.
    A buddy had an under hood setup on his truck and drilled it to help hide the fact he had one.
  14. Mike VV
    Mike VV
    from SoCal
    Don't bother with the holes. A LOT of work for little gain.
    I've got a later model car with a blower. The drive is a serpentine belt with small pulleys, it whines..! The best part of the drive !
    Get your wife some ear plugs, or muffs.
    Mike
    mad mikey and Acres like this.
  15. Acres
    Acres
    from Sweden
    The whine is one of the advantages of the blower besides more power and looks, take one of them away = whole concept ruined
    Buy her some of those phone earplugs thats popular nowadays, then she can listen too "music" and you can continue listen to that real whine music
  16. NoelC
    NoelC
    Get out the drill, it's a long cold winter.
  17. Bonehead II
    Bonehead II
    Boy ho Boy, you guys got some good ideas, But I don't think that she will go for it..
  18. harpo1313
    harpo1313
    from wareham,ma
    How does she like wheelies?
  19. 19Eddy30
    19Eddy30
    from VA
    Like most said about wife , maybe better that she does not ride, Tell her the buzzing in night stand is annoying,
    You can drill holes to let air escape, you will not brake pulley Nor never seen pulley failure, If you decide to keep the wife covert to serpentine
    (probably will have to be custom-made) then more likely will slip especially if
    6-71 or bigger & not least 2-1/4 wide belt , the wider the better , it can be made / done
  20. Everything about a 71 style blower induces whine. The gears, the rotors, the magical sound when the throttle is open and boost starts. It would be easy enough to take a pulley and put some holes in it but I question whether the results would justify it. Most of those I saw drilled were the old 1/2" flat tooth which could only stand so much rpm and stress anyway. When I went from the 1/2 to the 8mm, the belt life almost tripled. Then the big blowers came out and the 14 and 11 mm drives came into play. However, at slow engine speeds, if all of the parts are good, you should be as quiet as possible. No boost, engine running on vacuum, gears good so there is a minimum of gear noise and rotor to rotor and case clearances correct so no scuffing. I would be curious of sound level with a DB meter. :) One thing to add, as I remember people were drilling the pulleys to reduce blowing the belt off at upper rpm.
    seb fontana and Budget36 like this.
  21. gsjohnny
    gsjohnny
    16 groove serpentine pulleys used on boats. looked to go that for the dragster. don't need belt protection.
    currently run 1/2 pulleys. cant hear any whine over the zoomies.
    seb fontana, mad mikey and Bob Lowry like this.
