drilling holes in SBC cast iron heads
Discussion in 'The Hokey Ass Message Board' started by tweakman, Apr 3, 2012.
  1. squirrel
    That would be as close to the intake manifold as you can get them, right?
  2. Shaggy
    Shaggy
    from Sultan, WA
    But so is a thermostat....
  3. pitman
    pitman
    I never was much for having to 'burp' the system in the newer stuff.
  4. 24riverview
    24riverview
    Probably shouldn't post these because of the filth but this has worked for 32 years on my car. Remember at the time seeing information (magazine article?) about where the proper place to drill was, mine are 1" up from bottom of head, 3" from intake bottom edge. Hard to see but the lower part of the thermostat housing is off a 60's vintage 250 Chevy 6 with the opening that originally went into the head welded shut and one extra hole tapped. Heads are tapped for 1/2" pipe.
  5. CutawayAl
    CutawayAl
    from MI
    You can buy a cast (or billet:eek:) piece that holds a t-stat and is set up for the two lines in, a bypass hose, and a connection for a radiator hose.
    http://www.jegs.com/p/Weiand/Weiand-Thermostat-Housings-Adapters/1594913/10002/-1
    Taking the coolant off the front of the ehads is a common thing to do on race cars. It eliminates the need for the intake manifold to handle the water coming out of the heads. It works fine on race cars, and can work fine on a street car too.
  6. hotrodbrad
    hotrodbrad
    from Tempe, AZ
    This....a lot of though went into the design of that block. You might think that ok cool the heads by doing that, but you cause a lot of turbulence doing that
  7. coopsdaddy
    coopsdaddy
    from oklahoma
    Good info guys, I think this is why the hamb is so great,thanks.
  8. coopsdaddy
    coopsdaddy
    from oklahoma
  9. coopsdaddy
    coopsdaddy
    from oklahoma
    Using a remote thermostat would be the same setup only with a thermostat,still have to drill heads?
  10. coopsdaddy
    coopsdaddy
    from oklahoma
    Does anybody have a round pop off spring for a cragar intake, I'm missing one,thanks
