Hot Rods drilling tappered hole in I-beam to mount shock? safe?
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Jan 15, 2016.
  1. '52 F-3
    '52 F-3
    from Central PA
    I'm having issues deciding on my lower front shock mount. I've consider many places and am currently leaning towards drilling a hole to mount a shock stud like this.
    I just don't see this very much and am wondering if there is a reason?
  2. 55willys
    55willys
    That should work, your upper shock mount will be long and your shock quite angular therefore less effective.
  3. spinout
    spinout
    from Dallas, TX
    Can you move it closer in? Something to ponder.
  4. Tim
    Tim
    from KCMO
    Did them that way from the factory in the late 40's
  5. verde742
    verde742
    Just weld a bolt there, then use a spacer, washer.
    back to regular programming
  6. '52 F-3
    '52 F-3
    from Central PA
    as simple as it sounds it just been difficult to decide. I really like behind the I beam look, and my headlight mount is going to be fairly low. I plan to lean the upper shock tower out alittle bit to minimize the shock angle.
    picture shows what i'm thinking except behind axle.
  7. Tim
    Tim
    from KCMO
    Sounds good to me. Take a look at a stock 48 ford for how they did it. It's pretty much what you've got right there though
  8. BJR
    BJR
    Just don't mount the shock upside down like the picture.
  9. Happydaze
    Happydaze
    One more hole is going to make any difference? ;)
    Chris
  10. pila38
    pila38
    I did it on my Chevy axle. I don't see any issues with it, especially since guys drill axles all the time. Of course, I haven't driven mine yet, so take my advice sparingly.
  11. '52 F-3
    '52 F-3
    from Central PA
    thanks for all the replies, I was thinking I was over thinking it (this often happens)
    Tim,
    i'm search for some interweb pictures now, thanks
  12. pila38
    pila38
    I'm a hack, but you can check my build thread for what I did. I thought my ideas were fantastic, but don't I always.
