Drip rail removal
Discussion in 'The Hokey Ass Message Board' started by Jarhead1986, May 12, 2012.
  1. Jarhead1986
    Jarhead1986
    Anybody removed the drip rail from a 57 or 58 ford
    Fairlane or custom 300?
  2. Ford blue blood
    Ford blue blood
    Yup, need an old church key. Use the bottle opener end with duct tape loosely wrapped around it, catch the side under the drip rail and carefully start easing it out ward. Start ay the windshield end, be slow and carefull so as to not dent the stainless. Once it is started it comes off easilly.
  3. Jarhead1986
    Jarhead1986
    I ment removing the actual drip rail itself.
  4. Ford blue blood
    Ford blue blood
    Nope...never done that.
  5. imperialman67
    imperialman67
    from minnesota
    Yup I followed these instructions exactly when trying to remove the stainless drip rail from my 67 Imperial. CAREFULLY took my taped church key ,eased it under the molding CAREFULLY pried up on the molding and proceeded to F#ck it up.
  6. mgtstumpy
    mgtstumpy
    I've seen it done on other cars where the metal edge was ground back and the edge fuse welded together tying all the steel sections together before being lead wiped.
  7. Colin HD
    Colin HD
    Did it to a Mini in the UK, just what mgtstumpy said, but went with cheap plastic filler, no money or thoughts of lead!!! I was 17!!!!
    Would work on 57/58 Ford.
  8. nwbhotrod
    nwbhotrod
    from wash state
    Why tell me why you would do that
  9. Jarhead1986
    Jarhead1986
    Why ask why
  10. Jarhead1986
    Jarhead1986
    I saw a 49 ford in a mag Friday and it was gone from it. Looked good.
  11. Good for lettin' rain in.
  12. Retro Jim
    Retro Jim
    I think the body lines wouldn't look right on the roof with the drip edge removed . The rounder tops like the shoebox can get away with the drip edge removed but the later 50's Fords just don't look good with them removed .
    I have a 55 Ford and thought about removing them but it was too much work and I didn't think it would look right either .
    In the end it's your car so you can do what you want to it ! BUT just remember when it's gone , it's gone !
    Just my opinion .
    Retro Jim
  13. Jarhead1986
    Jarhead1986
    It looked like a can of worms. That's why I asked.
  14. Jarhead1986
    Jarhead1986
    Hey Blue Hood. You know where any 58 parts are layin around in Bham?
  15. I think the "too much work," took over before you got to what it would look like. To each his own. It probably is a lot of work but if you want to do it, go for it. None of us would know what a chopped top would look like if it was too much work.Keep us posted.
  16. Jarhead1986
    Jarhead1986
    I might try it on a donor car first and see what that
    uncovers
  17. There you go. Smart thinking.
  18. studebakerdave
    studebakerdave
    that was cool in the 80's I would really think about it and then not do it.
  19. Jarhead1986
    Jarhead1986
    I'm from the 80's but I love 50's and 60's fords.
  20. lukey
    lukey
    So what did you decide? Rather than removing them, check out McPhails 56 chevy. He folded the driprail over and contoured it into the body. Awesome look! I have considered it for my 58 also.
