Technical Drive shaft help
Discussion in 'The Hokey Ass Message Board' started by chop777, Oct 2, 2014.
  1. chop777
    chop777
    Anyone out there make driveshafts...
    I've got to go from c 4 to stock shoebox rear end.....
  2. Jalopy Joker
    Jalopy Joker
    where you live? need to narrow down area to locate someone close to you
  3. Most any good driveshaft shop can do that.
  4. Look on ebay, there's a guy that custom makes them for around $100-150 or so. you tell him length and u-joint size and they'll send it out. Worked on my chevy so far. Can't remember the sellers name sorry
  5. chop777
    chop777
    Just outside of charlotte....n.c.
    All the shops are 350 or so to build
    One ......I like the price of eBay guy more
    For sure
  6. 350 is a good price. It runs about 400 bones for a complete one here. Do you have the original drive shaft??? Maybe you just need to have it shortened and a new yolk put on??
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    Or you go the cheap route like I did on my '54Ford which uses the same style rear as your shoebox,get a drive shaft from a 1982-86 Crown Vic and this rear conversion U-joint : http://www.drivetrainamerica.com/p-6076-neapco-2-0291-2c1310-conversion-u-joint.aspx The Crown Vic shaft has the correct front yoke to work with your C4 or an AOD It is a bolt-in swap for 1952-56 Fords,you might have to shorten it a few inches since your shoebox has a slightly shorter wheelbase but that is a lot cheaper than buying a whole new shaft.
  8. chop777
    chop777
    Hey Jeff I have a 97 explorer drives haft
    That is perfect length ...would this u joint fit it....it's yoke is 3 5/8 with 1.061 bearing cups
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Give the link above a call they could give you all the specs,it only shows the bearing cup diameters on the link.
  10. ROADSTER1927
    ROADSTER1927
    You can probably find a conversion joint to fit. I have also combined two joints to make one that they did not make. My local shop has an old joint book that gives all the sizes for all the bearings and crosses. Find that listing and DO IT, Gary
  11. chop777
    chop777
    Picked up that joint from Napa for $35
    Fits my 97 explorer and a 85 Ltd
    And the wing bearing caps look right....
    Thanks for all of your help jeff
  12. Been a while since I've had a shaft built I guess......man that seems high as hell to me.
  13. Most wrecking yards have them in an area. Get your measurements, grab a tape and dial calipers and head out.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    [QUOTE
    Posted using the Full Custom H.A.M.B. App![/QUOTE]
    Same joint as the NEAPCO? What is the NAPA part number?
  15. chop777
    chop777
    Perfection part number 506
  16. chop777
    chop777
    Same joint as the NEAPCO? What is the NAPA part number?[/QUOTE]
    Forgot to quote
    Perfection 506 ......
    Works like a champ
    Thanks for your help
  17. pitman
    pitman
    Power of the HAMB!
    BTW, with a stick welder, a carpenters framing square and a hacksaw,
    you can shorten and if luck abides, fit yokes to construct almost any driveshaft.
    {Make the final tube cut square, cut a centerline into the yoke weld & grind the tube-half of the yoke weld, leaving the inner flange portion, clean the yoke up and phase it to agree w/the other one, pound it in square, tack 3-4 plcs, then weld evenly.}
