Drive shaft length?
Discussion in 'The Hokey Ass Message Board' started by Karl Fields, Dec 2, 2010.
  1. Karl Fields
    Karl Fields
    Back in the day I would push the yoke in, then pull it out about an inch and then measure center to center between front and rear ujoint caps.
    Well now I have this lowered thing, at drive height it's 44" using above method and at lowest slam it's 42". Is having the yoke out 2+" from the tail shaft, at drive height, a bad thing?
    I would guess the yoke is about 5" or 6" in length.
    Thanks
  2. fms427
    fms427
    I think you're within the "good" range - I've built similar cars. Your only other choice would be to play with rear suspension to see if you can change rear joint travel curve, but I wouldn't screw with it!
