Drive Shaft Measurment?
Discussion in 'The Hokey Ass Message Board' started by sanchez, Jul 17, 2011.
  1. sanchez
    sanchez
    from N.C.
    When measuring the drive shaft, how much of the yoke on the transmission should be exposed? "play" the car is on two jack stands that are placed under the axle. what is the correct way to measure?
  2. 1971BB427
    1971BB427
    from Oregon
    I generally bottom the yoke into the trans, and then back it out 1". Then measure from there. It really isn't a case of how much is exposed, as whther it is properly seated in the trans. Too deep and it binds, too shallow and it will break or drop out.
  3. sanchez
    sanchez
    from N.C.
    does it matter how the car is sitting? jack stands, etc.....
  4. sanchez
    sanchez
    from N.C.
    with the car on jack stands on the axle housing, i have 1 1/2 inches of yoke coming out of the transmission....
  5. Engine man
    Engine man
    from Wisconsin
    It's best to check with whoever is building your driveshaft.
  6. niceguyede
    niceguyede
    from dallas
    The guys I use for driveshafts dont want it measured with the yolk in. They want from the end of the tailshaft to the center of the u joint. This way they get it right every time. It should be on stands to simulate sitting on the suspension. I usually get 2 measurements- 1 suspension loaded and one not. check with who your using though, cause they're all different.
  7. George
    George
    As was said in #2, you slide the yoke in untill it bottoms out, then slide it back out 1", is typical.
    That's top advice there!:) My guy wants the distance from the center of the joint in the yoke to the flat on the U joint mount, it varies
  8. 48 Poncho
    48 Poncho
    from Tennessee
    I just got mine built. The guy said bottom the yoke out and pull back 3/4 of an inch then measure from center to center of the universals.
    48 Poncho
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That's top advice there!:) My guy wants the distance from the center of the joint in the yoke to the flat on the U joint mount, it varies[/QUOTE]
    X2, It's all about who you take it to. I gave my C/L deminsions to a shop, they didn't want that and would not do it without there set way of measureing.
  10. 69fury
    69fury
    from Topeka
    everyone i've dealt with wants it bottomed, then pulled out 1 inch.
  11. larryj
    larryj
    from Madison AL
    One local shop wanted it measured without the yoke, from end of tail shaft. Another wanted it measured with the yoke seated then pulled out one inch. Both wanted the car sitting on the ground normally loaded, I.e. at normal ride height.
    Check with your builder and do it his way. That makes him more responsible for the final result.
  12. Mr48chev
    That is probably too much sticking out. Most sources say between 3/4 and 1 inch and you want the vehicle to sit as it would going down the road. Having the car supported with stands under the rear axle when you measure is good though as the weight is still on the axle.
  13. mysteryman
    mysteryman
    from atlanta
    between 3/4 and 1 inch back
  14. Totally agree, 1 inch is pretty standard.
  15. Keep
    Keep
    I took pics of mine with the tape measure from the tail shaft to the diff. Going in each direction, printed out the pics and took them in. Made things real easy.
    Of course mine has a hard mounted jag so I did not have to worry about suspension travel.
  16. sanchez
    sanchez
    from N.C.
    Thank you to everyone for the advice, it is greatly appericated!
  17. tig master
    tig master
    from up north
