1952-59 Ford Drive shaft /Slip Yoke for Toploader?
Discussion in 'Off Topic Hot Rods & Customs' started by cafeswartz, May 25, 2015.
  1. cafeswartz
    cafeswartz
    from Canada
    Just putting in the 302 in the Ranch Wagon . The trans is a Toploader from a 68 Mustang /Cougar RUG E2 on the tag.
    Can I get some help on where to go for yokes ? Drive shaft will be custom .
    I have read lots on this forum and thank you . Now that we're down to doing the job I see I missed a post or two .
  2. Paul2748
    Paul2748
    Check with the guy who does your driveshaft. The guy who did mine had a bunch of books and found one for me. You may have to count the teeth on the output shaft and the diameter of the output shaft.
  3. mjlangley
    mjlangley
    from SE MI
    That model trans is probably a 28 spline output which is fairly common a****st Fords (C4, 3-speed, etc.). I would agree with the comment above, if you are having a custom shaft made that shop can likely source one for you.
