drive shaft tech request
Discussion in 'The Hokey Ass Message Board' started by voneyeball, Jan 22, 2004.
  1. voneyeball
    voneyeball
    Alliance Vendor
    any homegrown methods of balancing a driveshaft?
    thanks in advance
  2. old beet
    old beet
    Ya! Hose clamp and some flat lead. Trial and error method. ..........OLDBEET
  3. A kind of hokey way is to jack up the car. Run it slowly or spin the shaft by hand. As the driveshaft is spinning SLOWLY, hold a piece of chalk up to it so the eccentric, or out of round part hits it. it will leave a mark. Then place large hose clamps on the shaft with the screw part opposite the marks. You will have to test run a bit to get the vibe out. Then either leave the clamps or remove them and weld the same weight onto the shaft.
    A shop teacher told me this a long time and many many beers ago, so if I missed something please add to it. I did this once and it seemed to work.
  4. Toqwik
    Toqwik
    For the money, just take it and have it done. Yesterday, I took my driveshaft and they cut it down, balanced it, and replaced both ujoints. total cost was 58 bucks including tax and was done in less than 2 hours. Vibrations and rattles drive me nuts....
  5. voneyeball
    voneyeball
    Alliance Vendor
    i am a tight ***ed scrooge penney pincher. mainly 'cause i'm broke. think i sold the truck anyways... may not be my worry anymore.
    thanks for the tips tho! will try if i HAVE to.
    anymore??
